Help charging problem asus x550ze
  • nurianto
    • Mar 2016
    • 10
    • indonesia
    please help, im sorry i use google translate
    I have replaced the new battery and replaced the IC charger, but it is still wet when charging. the condition was charging but quickly ran out
    when using a supply without battery, the charger indicator lights up
  • kodox
    • Jul 2017
    • 328
    • Indonesia
    Re: Help charging problem asus x550ze
    maksudnya gimana mas "charging but quickly ran out"?
    • nurianto
      • Mar 2016
      • 10
      • indonesia
      Kondisinya ngeces tp cepet habis, kayaknya cuman detec 1 cell batrenya padahal batre baru.
      Ic chargernya bq25
      Pin 5 ACOK = 3v.
      Pin 6 acdet = 2,5v
      Pin 19 phase = 16v pake batre atau tanpa batre sama
      • kodox
        • Jul 2017
        • 328
        • Indonesia
        sudah coba flash bios?
        soalnya kasusnya sama seperti toshiba L745, status di windownya charging tapi isi batre turun terus
        • nurianto
          • Mar 2016
          • 10
          • indonesia
          Udh d flash dri versi 202 smpe 208 sama aja, bios KBC ite8528e itu bisa d flash apa gk?
          • kodox
            • Jul 2017
            • 328
            • Indonesia
            mungkin maksudnya bq24725 ya mas?
            kalo tanpa batre, tegangan di pin positif konektor batre berapa volt?
            sudah coba ganti adaptor? di PJP8502 terbaca berapa volt waktu pake batre aja dan berapa volt kalo pake adaptor aja?
            • nurianto
              • Mar 2016
              • 10
              • indonesia
              Pake psu tanpa batre pin out konektornya 16v pake batre skitar 11v
              • kodox
                • Jul 2017
                • 328
                • Indonesia
                PIN 4 & PIN 11 berapa volt?
                • nurianto
                  • Mar 2016
                  • 10
                  • indonesia
                  gk jd d lanjut bang sma usernya d cancel
                  • Scoff
                    HP Probook 470 G4 - Power and Charging Problem
                    by Scoff
                    Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                    Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                    07-03-2023, 09:28 AM
                  • sebkarimpour@gmail.com
                    Asus ROG gl552vw charging problem
                    by sebkarimpour@gmail.com
                    Hi guys
                    I have an Asus gl 552vw .it's show plugged in charging but it's never up charging level from zero percent .all voltage in battery socket sems ok
                    From right first 2 pins have about 16.8 volt and pin 5and 6 have 3.27 volt after unplugging charger voltag level in sockets show 0 I flash bios .and replace MOSFET that directly connected to positive pin of battery socket .I replace charger ic too .but no result yet .thanks for your suggestions and attention
                    09-09-2023, 02:05 PM
                  • lazaro.089
                    Asus Zephyrus M16 / GU603ZW problem
                    by lazaro.089
                    Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                    CPU: Core i9-12900H
                    Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                    Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                    The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                    08-26-2025, 06:33 PM
                  • medinfo
                    ASUS Zenbook UX360UA Battery charging problem
                    by medinfo
                    only charges about 10 seconds and stop charging, i need to unplug and reconnect the AC adapter to resume charging.
                    Bios updated.
                    Charger original and replaced.
                    [MOD EDIT]
                    Link to Boardview https://www.badcaps.net/forum/showthread.php?t=125687
                    Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
                    11-07-2023, 08:45 AM
                  • ahmarzo
                    Hp laptop charging problem
                    by ahmarzo
                    Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
                    Charging ic is bq737 with voltages on pin no
                    1&2 -19v
                    34&5 -0v
                    6 -2.56 v
                    7- 0v
                    8&9 -3.15v
                    10 -0v
                    11 -0.18v
                    12 & 13 -13v
                    14&15 -0v
                    16 -6v
                    17;18&19 -13v
                    20 - 19v
                    Voltages on battery connector are
                    1&2. -13v
                    3&4 -3.14 v
                    5&6 -0v
                    8&9 are ground...
                    03-20-2025, 05:13 AM
