Asus ROG gl552vw charging problem
  • sebkarimpour@gmail.com
    Valiasr
    • Aug 2019
    • 25
    • Iran
    Hi guys
    I have an Asus gl 552vw .it's show plugged in charging but it's never up charging level from zero percent .all voltage in battery socket sems ok
    From right first 2 pins have about 16.8 volt and pin 5and 6 have 3.27 volt after unplugging charger voltag level in sockets show 0 I flash bios .and replace MOSFET that directly connected to positive pin of battery socket .I replace charger ic too .but no result yet .thanks for your suggestions and attention
  • Sephir0th
    • Oct 2020
    • 1283
    Re: Asus ROG gl552vw charging problem
    Since we're not truthtellers here, it would be nice if you add some pictures along with your observations.
    One basic thing which can be easily ruled out is a shorted DC-IN Mosfet
    FairRepair on YouTube
    • Scoff
      HP Probook 470 G4 - Power and Charging Problem
      by Scoff
      Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
      Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
      07-03-2023, 09:28 AM
    • lazaro.089
      Asus Zephyrus M16 / GU603ZW problem
      by lazaro.089
      Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
      CPU: Core i9-12900H
      Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
      Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
      The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
      08-26-2025, 06:33 PM
    • medinfo
      ASUS Zenbook UX360UA Battery charging problem
      by medinfo
      only charges about 10 seconds and stop charging, i need to unplug and reconnect the AC adapter to resume charging.
      Bios updated.
      Charger original and replaced.
      [MOD EDIT]
      Link to Boardview https://www.badcaps.net/forum/showthread.php?t=125687
      Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
      11-07-2023, 08:45 AM
    • ahmarzo
      Hp laptop charging problem
      by ahmarzo
      Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
      Charging ic is bq737 with voltages on pin no
      1&2 -19v
      34&5 -0v
      6 -2.56 v
      7- 0v
      8&9 -3.15v
      10 -0v
      11 -0.18v
      12 & 13 -13v
      14&15 -0v
      16 -6v
      17;18&19 -13v
      20 - 19v
      Voltages on battery connector are
      1&2. -13v
      3&4 -3.14 v
      5&6 -0v
      8&9 are ground...
      03-20-2025, 05:13 AM
    • AtelierRepa
      ASUS X712JA problem
      by AtelierRepa
      I have a problem with the bios, let me explain.
      With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
      I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
      My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
      The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
      06-15-2024, 04:33 AM
