Sony Vaio VPCEB MBX-224 no image but backlight and hdmi works
  • sn4k3
    • Oct 2016
    • 68
    • Portugal
    I have a Sony Vaio VPCEB4Z1E MBX-224, it suddenly stop outputing image to LCD, backlight always works. Tried external monitor and is ok, both VGA and HDMI is able to output image to the external monitor, but internal still without image. Then i buy a new panel but the problem presist. Since i have another equal pc layarround i tried to replace LVDS cable, nothing changed.
    After looking schemantics i probe TP's on lcd connector with PC ON, every TP shows voltage.
    LCDVCC: 3.3V
    ATI lines: 1.2V
    INV_: 3.3V
    DCBATOUT: 19V
    What can be wrong?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Sony Vaio VPCEB MBX-224 no image but backlight and hdmi works
    White or black background on the display? No liquid damage?
    If black background, you can check every LVDS line (ATI_*) in diode mode to ground, with display disconnected first then connected. All lines should measure the same within 1%.
    Might be bad GPU too.
    • sn4k3
      • Oct 2016
      • 68
      • Portugal
      black background. No damage, i have 3 LCDs with same model and try them all.
      Diode mode but with PC off in both stages right?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        bad ati gpu. Try mild reflow of ati gpu and then check.
        • sn4k3
          • Oct 2016
          • 68
          • Portugal
          I measure in diode mode, the lines are all +/- 0.478V and others 0.481V (With and without LCD connected, values are the same)
          • sn4k3
            • Oct 2016
            • 68
            • Portugal
            Fixed with reflow, it now have image and works normaly. Thanks
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              u just diagnose problem, no repair
              • sn4k3
                • Oct 2016
                • 68
                • Portugal
                I know reflow is temporary fix, permanent GPU repair require a new gpu solder in. But this will do for the purpose of this old laptop. Regards
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3627
                  • slovakia
                  reball it
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    Why reball? This needs a new GPU.
                    If it can last a few more days/weeks/months with just a little bit of heat then sometimes it's good enough, but indeed it's not fixed.
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3627
                      • slovakia
                      reball often last much longer than reflow
                      • sn4k3
                        • Oct 2016
                        • 68
                        • Portugal
                        That's true, but problem with GPUs these days are not the balls most of the times. A reflow and/or reball can fix broken or bad contact with pad/ball joint but we know GPUs goes bad internally and heat expand circuit remove shorts sometimes. Also we can't reball the micro balls from DIE.
                        In other hand is hard to find brand new GPU's, they will be used and refurbished most of the times on china market (ali, ebay) so don't seens a great solution either. So my preference is reflow first, if it holds great, if not then look futher to replace GPU. I often skip reball because most of the time just end in a time waste fixing nothing that reflow can't
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3627
                          • slovakia
                          even with internal die problem, reball lasts longer
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Yeh, reball lasts longer then reflow but i too dont prefer reballing GPU as this is no solution. It normally comes back to bench within 3-4 months. If i can get a reliable chip, then only i replace-else i return it to customer. New gpu and that too reliable-is something very hard to found and in some series simply not avlbl at all.
                              Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                              This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 05:27 AM
                              Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                              This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                              Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                              This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                              This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            • Carlos#2003%
                              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                              by Carlos#2003%
                              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                              02-15-2024, 07:52 PM
