TOSHIBA L500-1QE LA-4982P no power
  • manol278
    • Nov 2017
    • 41
    • greece
    TOSHIBA L500-1QE KSWAA LA-4982P REV 1.0 with VGA ATI 216-0728014
    no power, no led signal.
    PQ8 MOSFET-
    PIN 1 - 18,7
    PIN 2 - 18,7
    PIN 3 - 18,7
    PIN 4 - 18,7
    PIN 5 - 18,2
    PIN 6 - 18,2
    PIN 7 - 18,2
    PIN 8 - 18,2
    PQ9 MOSFET-
    PIN 1 - 18,7
    PIN 2 - 18,7
    PIN 3 - 18,7
    PIN 4 - 18,7
    PIN 5 - 3,2
    PIN 6 - 3,2
    PIN 7 - 3,2
    PIN 8 - 3,2
    U46 BIOS MX25L160
    ALL PINS - 0
    PLease help me! Thanks.
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: TOSHIBA L500-1QE LA-4982P no power
    PQ8 MOSFET-
    PIN 1 - 18,7
    PIN 2 - 18,7
    PIN 3 - 18,7
    PIN 4 - 18,7
    PIN 5 - 18,2
    PIN 6 - 18,2
    PIN 7 - 18,2
    PIN 8 - 18,2
    PQ9 MOSFET-
    PIN 1 - 18,7
    PIN 2 - 18,7
    PIN 3 - 18,7
    PIN 4 - 18,7
    PIN 5 - 3,2
    PIN 6 - 3,2
    PIN 7 - 3,2
    PIN 8 - 3,2
    U46 BIOS MX25L160
    ALL PINS - 0
    the Voltages on PQ8 PQ9 not correct output pin 5678 of PQ9 must be 18.2V
    first test you Fets for any short & Ohms
    • manol278
      • Nov 2017
      • 41
      • greece
      PQ8 and PQ9 removed and replaced
      PQ8 5678 to GND is about 58kohms
      PQ9 5678 to GND is about 0,4kohms
      • Techtiger
        • Oct 2014
        • 1601
        • france
        Test Voltage on PR67 both sides , try to find in GOOGLE how to test P-Channel fet S D G you have to check between don’t replace if you’re not sure
        • manol278
          • Nov 2017
          • 41
          • greece
          I cant find PR67....
          • Techtiger
            • Oct 2014
            • 1601
            • france
            ok then voltage on all legs PQ19
            • manol278
              • Nov 2017
              • 41
              • greece
              Voltage on all legs PQ19
              • Techtiger
                • Oct 2014
                • 1601
                • france
                PU1 A IC pin1 you should get 3.3V find that IC, PQ19 gate voltage should be 3.3V PACIN, what is the charger you are using try with another charger if you have uplode both side of the Mob in 2 pic
                • manol278
                  • Nov 2017
                  • 41
                  • greece
                  PQ19 gate voltage 18V???
                  • Techtiger
                    • Oct 2014
                    • 1601
                    • france
                    PQ19 gate voltage must reach 3.3V this voltage come from LM393 PU1 comparator pin 1 3.5V through the Power diode PD1 one side 3.3V test the Voltage & PR67 but the register he’s not marked anywhere you have to do a continue to test to find out one side of PD1 is connected to that register PR67
                    • manol278
                      • Nov 2017
                      • 41
                      • greece
                      PQ19 gate voltage must reach 3.3V this voltage come from LM393 PU1 comparator pin 1 3.5V through the Power diode PD1 one side 3.3V test the Voltage & PR67 but the register he's not marked anywhere you have to do a continue to test to find out one side of PD1 is connected to that register PR67
                      Sorry but only you can help me...
                      • Techtiger
                        • Oct 2014
                        • 1601
                        • france
                        voltage on PD1 ? put the Multimeter meter in continuity mode and test how may Restarters of next to PD1 connected with the it
                        • manol278
                          • Nov 2017
                          • 41
                          • greece
                          For a strange reason when i test Restarters of next to PD1,after that the laptop work....
                          Maybe a short somewhere...??/
                          • manol278
                            • Nov 2017
                            • 41
                            • greece
                            techtiger thank you for your help...
                            • Techtiger
                              • Oct 2014
                              • 1601
                              • france
                              no worries ,breaking solder joints may be the cause in that area you may have to heat up with some flux over heating might kill the Mob
                              • FSMaker
                                • Feb 2025
                                • ITALY
                                I have the same problem, when test PD1 led turn on..but dont't turn on when i press power button..
                                  09-06-2024, 05:27 AM
                                  09-06-2024, 05:59 AM
                                  09-06-2024, 05:33 AM
