laptop Medion Akoya MD 9764 does not work anymore
    hello my laptop Medion Akoya MD 9764
    does not start the lamp goes on but no function
    many thanks
    Re: laptop Medion Akoya MD 9764 does not work anymore
    Here are pictures of motherboard
      check which ICs get warm or hot and which voltage rails are present on the mainboard.
        Hello, thank you
        I have 19 3.3 5 volts
        the laptop goes on and fan still lives
        an IC gets slightly warm
        Medion S5612 67M6F011C1 E222034 0925 21
          is not this Bios problem or do I have to search for Bios Dump ???
            it is possible to be a Bios problem, but more probably it is a GPU problem. In addition, a few other problems are possible. Does the CPU or the GPU have voltage on this mainboard?
              I have not found a bios update,
              a request how to check CPU or GPU voltage ??
              many thanks
                CPU or GPU voltages can be found on the coils near them. If you did not find those coils, measure voltage on all square-shape coils on the mainboard.
                  which chip is the bios chip ??
                  I have here two pieces of marked chip once yellow and pink
                    Here`s a bios you can try,and a schematic.The motherboard is made by a MSI. x600 ms-16911. Backup and verify your bios backup before flashing a new one.
                    Bios: https://www.badcaps.net/forum/showthread.php?t=44094
                      Hello and thank you
                      if i update this bios, i need to re-enable windows 10 pro or ??
                        what differences exist between BIOS update and a dump ??
                          If you upgraded to win 10 you will have a digital entitlement key. You can find out what that key is with showkeyplus software. Use the x32/x64 version,not store one https://www.softpedia.com/get/System...wKeyPlus.shtml
                          EDIT: i tried opening those bios i linked to ,part 2 is corrupt , don`t flash it !
                          EDIT 2: I found the dumps on another forum .
                            unfortunately I have no contact with Bios MX25L512 chip
                              Hello
                              I had to desolder the Bios chip, otherwise I had no use
                              I can now read all the info, how can I tell that I have bios problems before writing anything on it
                              can someone help me?
                              many thanks
                                unfortunately no success
                                I have to concentrate on CPU and GPU now and I need help
                                  did you buy it from aldi ?
                                    yes I had bought that from Aldi,
                                    I have in marked places pieps tone, capacitors
                                      PQ8 looks damaged .
                                        hello no that's left of glue
