asus x451UA no ACOK
    Re: asus x451UA no ACOK
    Originally posted by khaahk View Post
    Learning through experience is sometimes time consuming.
    Good microscope should be of help in these cases.
    Good work!
    and not to forget about quality flux. Cheaper flux and soldering paste is the issue of ic's not soldered properly.
      Good mornig, after checking voltage and replacing charge ic, and still battery did not charge i noticed that the enable of the battery was not grounded. After grounding H6001 battery is working and charging. I hope this wil help in future somone with the same problem.
        Hi ihave the same issue I got only reading on
        ACOK -6V
        ACDET -2.7
        PMON -3V
        CMPOUT-6V
        REVN-6V
        BTST-6V
        HIDRV 6V
        VCC- 19V
        Other pins 0v
          ACOK 6V is not good, it should be 3.3. Replace BQ24780S charging IC.
          A working TV? How boring!
            I tried to change it with a new ic but no luck same voltage at acok
