Laptop LCD display brightness issue
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: Laptop LCD display brightness issue
    Backlight is controlled from SIO by BL PWM signal that drive mosfet. u can check PWM signal and remove mosfet to drive BL with PSU. mosfet can be shorted so BL goes on full brightness no matter what signal is getting
    • raajkumar
      • Mar 2015
      • 354
      • Srilanka
      INV_DA: KBCoutput D/A signal(adjust voltage level)to adjust Back light
      • andyred
        • Aug 2012
        • 13
        @ktmmotocross, only if I can find that mosfet. Any idea where could it be located?
        @raakjumar don't understand what you're trying to say there
          • 20659
          The screen is eDP,can the mosfet be built into it or the motherboard ? ,i`m not sure reading the eDP spec .
            • 20659
            [QUOTE=andyred;890072]@ktmmotocross, only if I can find that mosfet. Any idea where could it be located?
            You need the boardview, i`ve already posted that if you make a request, someone may be kind enough to post it,if they have it.
            http://sualaptop365.edu.vn/threads/a...rdviewer.1110/
            • andyred
              • Aug 2012
              • 13
              A strange thing that I've noticed just now. I can modify from the Intel HD graphics control panel the color brightness to a minimum value of -60 (color brightness, I have no screen brightness option available) Once I remove the AC cord and it remains only on battery the brightness goes up to maximum again but the -60 value remains unchanged.
              I really don't understand what is going on here
              • andyred
                • Aug 2012
                • 13
                I've checked today the mosfets, none are shorted.
