I have an Acer Aspire ES1-521 laptop that has no power from either the battery or the ac adaptor and no power lights on the computer? I checked the ac adaptor which is working fine. tried another with the same voltage and amperage. I opened up the computer and removed the Ram, Hard Drive and added thermal grease to the heat sink. the voltage to the board on the power connector is 19v. I disconnected the battery held the power button for 30 seconds nothing worked. This mother board has the cpu soldered to the board. Even though I have 19 v to the board I have no idea where it goes from there or where it is suppose to go. Can someone tell me the probable causes. There is a lot of talk in here on Bios corruption could this be a cause or is it most likely a dead mother board? Any help greatly appreciated
Acer Aspire ES1-521 No power no lights on battery or adaptor
Re: Acer Aspire ES1-521 No power no lights on battery or adaptor
Originally posted by mcplslg123 View PostCheck 3v and 5v ALW present or not??Last edited by davg; 03-25-2019, 05:52 AM.
Originally posted by ktmmotocross View Postas first u must check if there is 19V after second mosfet on DC line. if not than u must check charger ic like BQ
Ok I have narrowed the problem down to the video connector? or the lcd itself. It is now working on an external monitor but as soon as I plug in the on board video connector it shuts down??Last edited by davg; 03-25-2019, 09:32 AM.
Bad cable or bad panel shorting backlight rail to ground maybeOpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Originally posted by piernov View PostBad cable or bad panel shorting backlight rail to ground maybe
