A friend tried to install a new KB on his Asus X450CC which was working properly, except for dead keys, and afterwords the laptop is dead- no charging light, no quarter fan spin, no signs of life. He did not install the keyboard IO shield so I suspect the bottom of the KB touched the mobo and shorted some component. There is no obvious physical damage to the board, and no visibly burned components. Will post some board pics
Asus X450CC
Re: Asus X450CC
when its not anything wisibly burned why do u think this photo will help?
dont u think some measurement will be better help?Last edited by ktmmotocross; 02-11-2019, 02:28 PM.Comment
Re: Asus X450CC
In this model of laptop, the keyboard is tightly connected to the laptop's upper cover so that the keyboard will not touch the mainboard. but If you want to replace the keyboard, you should install a number of rubber cubes on the mainboard to hold the keyboard up.
just look at the mainboard to see which components have high probability of being shorted by keyboard's metal surface.Comment
Re: Asus X450CC
Here are the latest updated readings. This area of the board seems most likely to have been touched by the kb. I've also attached the board view for this mobo. Also noticed a loud whine which appears to be coming from the cap on the bottom of the board, PCE8101, which is underneath the pictured area.
Attached FilesComment
Re: Asus X450CC
start from begining. so thats measuring every big grey coil on board for voltage and resistance to groundComment
Re: Asus X450CC
Why waste time taking zero readings from "every big grey coil on board for voltage and resistance to ground" when the board is "dead"
The mind bogglesComment
Re: Asus X450CC
This is how every amateur wastes so much time trying to find a fault. The laptop is dead so the beginning is where the dc enters the board. Readings from there will soon pinpoint the fault area.
Re: Asus X450CC
Measuring voltage and resistance to ground on every coil is very easy and quick to do, and will give a rough idea of what state the board is in, and help pinpointing where to concentrate on the power sequence.
It absolutely makes sense to do so in a no power situation.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Re: Asus X450CC
I assume PU8100 pin 15 = 8.6V is a typo and supposed to be .86V to match the .85V on the capacitor connected to it. This is the 3V linear regulator output. Check the resistance from here to ground. Though there may be another explanation for the low voltage..
There is something going on with the power rail feeding PU8100. You measured 19.28V on one side of PR8101 and 11.9V on the other. It is supposed to be a 1 ohm resistor, and could not possibly be dropping that much voltage without burning up. Double-check the voltage readings and check if its resistance has increased from the 1 ohm it is supposed to be.
And then that same 11.9V somehow measures as 12.4V at PU8100 pin 11 (VIN). Probably just fluctuated between the two readings though. Quite possible if the resistor is bad or something like that.
Incidentally, PU8100 is a UP1589Q, which is hard to get info for. However, it is compatible with the RT8239B and has the same pinout.Comment
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:00 AM
- Loading...
