HP 6910p hanging
  • akande
    • Dec 2017
    • 278
    • Nigeria
    HP 6910p hanging
    I have HP 6910p when powered on hang on logo, but if both side of the PC pressed with force to desk it work fine . I have washed the board with luck anyone with an idea to fix plz
  • triplefour
    LG 75UN8570AUD panel issue fixed with tape.
    by triplefour
    I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
    add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
    07-17-2023, 10:22 PM
  • mecha1166
    Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
    by mecha1166
    I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
    07-03-2024, 05:03 PM
  • reformatt
    Windows 11 Start menu/Taskbar hanging
    by reformatt
    Couple of Windows 11 machines have come in this week with the same issue. After you login, the taskbar will not appear (or just be a black bar). No access to Start Menu. Task Manager (use CTL+SHIFT+ESC) works, however the Performance stats seem stuck with CPU on 100% for Task Manager itself. Trying to exit Task Manager result in it hanging as well. No issue if you boot into Safe Mode.
    First machine, tried many things to no avail (System Restore from last Windows update, rebooting in Diag mode, trying to reinstall Windows Apps via Powershell). In the end, I did an in-place upgrade...
    04-23-2024, 10:16 PM
  • Tend0
    HP Compaq 6910p No post
    by Tend0
    Hello guys my hp 6910p power on but no post
    i think i was bios problem
    HP Compaq 6910P
    Mainboard: IBT00 LA-3262P (osp) Rev: 1B 2008-04-02
    SN:CND8424Z0Z
    Service Tag: C6910pUT7300W4X80GIBN20Qe
    Issue: No Post. No boot to os; and verry slow
    Thanks have a nice day !!!
    Original bios fil attach๐Ÿ‘‡๐Ÿ‘‡๐Ÿ‘‡...
    02-05-2024, 05:30 AM
  • dennis akumu
    hp elite desk 800 g3 twr bios
    by dennis akumu
    i have this elite desk 800 g3 tower with no display,need a clean me file.
    s/n : SGH802SMK4
    PRODUCT ID: 1VR31UC#ARE
    BOARD NO: Andromeda REV A
    Please clean me please....
    07-11-2025, 05:54 AM
