toshiba l850 repair
  • tor199812
    • Feb 2019
    • croatia
    toshiba l850 repair
    Hello everyone I have toshiba l850 at repair the symptoms are following :
    laptop automatically powers on when charger is connected screen is bleck motherboard use 1.3 ampere of current i am already done several things
    replacing gpu chip,replacing ram memory ,bios reprogramming ,cmos reset, cpu replacing ,all regulators have output voltages i am also put some heat tu vram
    and still nothing please help thanks in advance.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: toshiba l850 repair
    in older C2D systems auto power on means NB was bad
    • unimer
      • Feb 2019
      • 6
      • Slovenia
      I have the same problem with my Toshiba l850. When battery is in connected, and when I plug the charger it stays off. But when I plug a charger without battery connected then it turns on automatically. The screen is also black, and I don't get numlock light on the keyboard also. Did you solve problem with your Toshiba and what NB stands for, north bridge?
      Thanks in advance.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3628
        • slovakia
        Thanks in advance.
        better measure it. check all big coils for voltages
        • tor199812
          • Feb 2019
          • croatia
          when laptop starts automatically this i sign of short circuit because current hase path tu flow i my case short is on 3 alw voltage and caused by southbridge remove all soplay tu all blocks one bay one and measure resistance when you find short on for example on 3 v put sam voltage about 0.75 v and weit component tu heat up don't put more then 1 volt because of large current will flow a can damage other ic s as well.
            09-06-2024, 05:27 AM
          • zioricci
            Toshiba Satellite P855 charger disabled after a while
            by zioricci
            after a little operating time of my Toshiba laptop, ranging from about 20 to 45 minutes, the Power light goes off, the power supply switches from the charger to the battery and in fact the voltage of both gates of the 2 initial mosfets are at 0V so the 19V does not reach the PL201 inductor and the power comes only from the battery.
            However, when i close the cover to turn off the laptop, the charger starts working again, charges the battery and the Power light turns on in amber color but after about 20 minutes the charger is disabled and the power light...
            05-05-2023, 02:34 PM
            09-06-2024, 05:59 AM
