Hp g62 hdd and odd proplem
  • menshawy
    • Aug 2013
    • 400
    • egypt
    hi friends
    MB DAAX1JMBC0
    DONT DETECT HDD OR CDROM
    wrote new bios
    replaced pch mh55
    no new hdd and odd still not detected
    plz help
  • on/off
    • Oct 2016
    • 333
    • Indonesia
    Re: Hp g62 hdd and odd proplem
    Have you check 5V for HDD and ODD?
    • menshawy
      • Aug 2013
      • 400
      • egypt
      yes 5v ok
      cdrom power on normaly
      but some hdd power up and some not power up
      • EvazX
        ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
        by EvazX
        I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
        Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
        For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
        However, after some time, the replacement motherboard...
        08-25-2025, 06:09 PM
      • spacez
        XPS 15 9520 - tpm device is not detected - NO ssd detected
        by spacez
        I have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
        Service Tag: J2MSHW3
        |Express Service Code: 41518077843
        mother board LA-L402P REV 1.0(A00)​...
        08-18-2024, 10:54 PM
      • Nikan.e
        Inno 3d RTX2070 not detected - no I²C connection
        by Nikan.e
        Greetings and Salutations!
        I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
        The faulty DrMOS was removed, and the burned PCB area was milled away.
        All voltages are now good, but the GPU is not being detected.
        I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
        I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
        I thought these pins were used for communication during startup?!?
        On all...
        03-30-2025, 07:21 AM
      • superdota2
        HP 15s-FQ2552TU nvme drive not detected
        by superdota2
        HP 15s-FQ2552TU
        da0p5hmb8f1 rev f
        sn# 5CD138CCH4
        problem is power on but no display,no bios post
        i search bios here ,i found and it work and got display.
        https://www.badcaps.net/forum/showthread.php?t=104925
        second problem is nvme drive not detected in bios intel rapid storage,
        i tried a working nvme drive but still not detected in bios,
        also tried install system and install intel rapid driver,still not detected....
        06-21-2023, 09:36 PM
      • Scotchmist
        Lenovo thinkpad 15 itl g2 - No Hdd detected
        by Scotchmist
        Hi
        I got this laptop with bad onboard ram so edited the bios with SPD removal tool to disable the onboard ram and work with the ram slot - the laptop now posted so i thought all was good however when i put everything back together it will not boot to windows as no boot device found., In the bios is says hdd not detected, i disabled VMD in the bios but still the same, loaded windows on usb stick and windows install cannot find the hdd. I bought a second board that had water spill, repaired the damaged area and it posted ok but same issue no hdd detected.
        I have now tried...
        09-11-2024, 05:06 AM
