Dell inspiron 15 la-b843p charging issue
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    MODELELL INSPIRON 15-5000 SERIES
    PLATFORM: LA-B843P REV 1.0
    PROBLEM:PLUGGED IN CHARGING BUT PERCENT NOT GOING UP.
    Measurement of BQ737 with adapter plugged in with battery
    PIN01-19V
    PIN02-19V
    PIN03- 0V
    PIN04- 0V
    PIN05- 0V
    PIN06-2.46V
    PIN07- 0V
    PIN08-3.2V
    PIN09-3.2V
    PIN10-2.97V
    PIN11-2.97V
    PIN12-15.6V
    PIN13-15.6V
    PIN14- 0V
    PIN15- 0V
    PIN16-6.0V
    PIN17-15.3V
    PIN18-15.6V
    PIN19-15.6V
    PIN20-19V
    I know that pin 17/18/19v is wrong as pin18 is HIDRV and I'm not getting the requisite voltage and hence gate of Pu4405 is not opening. But i couldnt find it whats wrong.
    PU4201 pin4-3v and pu4402 pin4 is 1.7v which is correct.
    PQ4201 and PQ4202 Voltages are ok as per schematics.
    PR4205 is 33.3 Ohms and i"m getting PSID_EC signal.
    PD4401-pin2 is 6v but pin1 remains 15.6v.
    I've replaced BQ737 with a known good IC(same bq737) and even replaced PU4405/06 with SI412 but with no change.
    I request members here to guide me.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell inspiron 15 la-b843p charging issue
    Here is the schematics attached
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Btw, Repair was attempted on this mb by someone earlier before it came to my bench. Laptop was turning on only if backup battery is removed . Lot of wrong/mismatched components were removed/replaced and now it is showing plugged in charging but actually not charging.
      Battery is Dell original and is checked good on another laptop.
      • on/off
        • Oct 2016
        • 333
        • Indonesia
        Are you sure that schematic is match?
        For me your file is wistron iris. Very confuse...
        Btw, there was la-b843p on refixpro seem fit for you, but have no access to download it.
        I afraid the one who attempt to repair make more change lot position of components, even you bro.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Though schematic i have attached is for different platform but the charger is same and it matches perfectly with LA-B843P.
          Though the previous guy did a lot of wrong things but i have fixed them all and now the circuit is as it should be. So we can try to fix it.
          The only thing to bother is High and Low side charging circuit.
          • on/off
            • Oct 2016
            • 333
            • Indonesia
            Yes, you was correct. compare it HD image with those schematic seem ALL matched.
            Good idea compare it with HD image for last inpection.
            link HD image:
            https://drive.google.com/open?id=0Bw...2Vqdmh5T3F5cHc
            Thanks to Rimas.
            I think is fine, since schematic matched.
            Interesting.
            Maybe there are components near BATT socket was change value.(page 43)
            • smali
              • Sep 2014
              • 287
              • Pakistan
              check shortage or any leakage between the drain and source of pu4201 and pu4402..
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Both are ok. Checked them out of circuit as well.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Dear On/OFF, mb matches perfectly with the HD image link you provided though i already downloaded HD imahe from some russian forum and matched it. There is no missing components and all resistors, IC's i checked are found to be ok.
                  Any ideas guys...
                    • 21907
                    Can you check voltage on each pin of PR4204 and PR4205
                    • on/off
                      • Oct 2016
                      • 333
                      • Indonesia
                      Maybe KBC Chips need to re-flash. Since KBC chip is Host for charging circuit. I remember you have SVOD.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        kbc here is nuvoton285 which is not programmable.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          I'll measure and report back within next 2days. My office is under renovation as i'm adding some more equipments and changing the furniture.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Friends, finally problem solved though i could'nt understand the logic. Here is what happened::
                            01. I got another laptop(same specs, same mobo) for repair. It was dead and i fixed it.
                            02. I checked display and battery was charging on this laptop.
                            03.I checked the other battery(for which i started this thread) and it was charging. So battery was good.
                            04. Now, when i swapped the batteries between these two laptops -both laptops are charging battery. Restored back original batteries to the respective laptops-again one unit not charging.
                            So though problem solved but i'm still puzzled why the other battery is not charging in one mb but gets charged on the other mb.
                            • erhanabdullah
                              • Nov 2015
                              • 24
                              • turkey
                              I met this problem .I found problem on ID pin's voltage of adaptor .ID pin or other name PSID_EC voltage must be 3.3v. Defective resistor can be 130 ohm.Charge is ok and there is no message on boot
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Thats a different matter altogether. In my case psid_ec was ok at 3.3v.
                                • diegosgarcia81
                                  • Jul 2020
                                  • 4
                                  • Brasil
                                  i have same issue
                                  • danielsak
                                    Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                                    by danielsak
                                    Hello, I have issue with Dell Inspiron 3542.
                                    Motherboard marking:
                                    Code:
                                    PWB FX3MC REV: A00
                                    The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                                    1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                                    1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                                    10-11-2024, 04:36 PM
                                  • computerbacon79
                                    Dell Inspiron 3480 All in One corrupt Bios issue
                                    by computerbacon79
                                    The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
                                    05-06-2025, 06:43 PM
                                  • b4rdock
                                    Dell Inspiron 5755 battery 255% bios issue ?
                                    by b4rdock
                                    hi i have a dell Dell Inspiron 5755 i have try many battery like original new one
                                    issue battery charge to 255% and if disconnect charger lapton turn off
                                    Dell Inspiron 5755
                                    Model: P28E
                                    st: FTMG462
                                    motherboard number: AAL12 LA-C142P​
                                    bios attached
                                    can help
                                    regards...
                                    05-01-2024, 11:40 AM
                                    DELL Inspiron 3268 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                    This specification for the DELL Inspiron 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3268 boardview and Inspiron 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                    09-12-2024, 03:44 PM
                                    DELL Inspiron 3650 Inspiron 3000 i3-6100 Specification for Upgrade or Repair
                                    This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
