ASUS G501 cpu not turning on
  • myth77
    • Feb 2017
    • 380
    • Croatia
    The central pin on power jack was broken and shorted the motherboard...
    First i replaced power jack, then i find short on pch and it8585...Replaced pch and it8585...then i found short on PWM CONTROLLER NCP81103, so i replaced it also....as far as i can see i have voltage everywhere but cpu is not opening (Gpu is turning on 0,8v).
    all_system_pwrgd 3,3v
    h_dram_pwrgd 0,71v (low?)
    but on logic drampwrok is not opening, 0v!
    What am i missing? the resistence on +vcore is arround 30 ohm!
    I attached the boardview, its the same as g501 just flip the board horizontally.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: ASUS G501 cpu not turning on
    this boardview file is strange that it does not show the ICs properly.
    It seems the CPU_Core circuit is still not working. So check the CPU_Core controller and its Mosfets.
    • piernov
      • Jan 2016
      • 4439
      • France
      You have PM_PWROK_PCH and PM_SYSPWROK_PCH? 25Mhz PCH clock present?
      • questore
        • Dec 2015
        • 564
        • csongrád
        Check U0303 for short.
        if no short then check U0303:
        - pin1 should be 3v
        - pin2 should be 3v
        - pin5 should be 3v
        if these pins are all 3v then replace U0303.
        • hs.leomessi@gmail.com
          • Feb 2022
          • 9
          • iran
          Re: ASUS G501JW bios needed
          asus g501jw bios needed
          main and EC
          • mon2
            • 14672
            BIOS requests are in a different section of this forum.
