latitude D610 bios flashing
  • Siddig
    • Jun 2017
    • 264
    • Sudan
    hi bro
    how I can flashing spi 40 pin for latitude d610 by SVOD3 OR RT809F PROGRAMMER .
    spi chip: ST Micro M29W008AB/AMD-29LV081B/SST39VF080.
    • 21948
    Re: latitude D610 bios flashing
    The M29W008AB/AMD-29LV081B/SST39VF080 are all TSOP40 .For the RT809F you need a PEB1 expansion board and TSOP adapter
    • Siddig
      • Jun 2017
      • 264
      • Sudan
      thanks fo replay dear
      I have RT809F WITH PEB1 EXPANSION BOARD BUT I HAVN'T TSOP40 adapter.
      no others way with out TSOP40 adapter?
        • 21948
        I don`t know, i have a tl866 with TSOP adapters .If you know the pinout of the PEB1 socket you could solder wires direct to the bios pins.
        • Sathsul
          Dell Latitude 5431 issues with dumping bios
          by Sathsul
          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
          10-28-2025, 07:49 AM
        • kenkaniff
          HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
          by kenkaniff
          Product Name: HP Pro x360 Fortis 11-inch G9
          System BIOS: U94 Ver.01.08.00 10/06/2023
          Serial Number: 5CG31946F5
          SKU Number: 85W05EC#AK8
          Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
          This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
          I needed to remove bios password...
          10-01-2025, 04:32 AM
        • TripTop
          Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
          by TripTop
          Hi
          i have dell latitude E7270 with following symptoms:
          - takes long time to restart.
          - sometimes powers on and then off
          - sometimes while working it just dies,
          From googling online bios clean could possible resolve this?
          i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
          As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
          I reinstall...
          09-09-2024, 02:05 PM
        • gizaha
          by gizaha
          02-13-2024, 07:18 AM
        • Loli Popu
          DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
          by Loli Popu
          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
          12-13-2024, 08:29 AM
