Nm-a272 cpu start to heat if plug power adapter
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hello I'm new here I have a certain problem my NM-A272 board start to heat the CPU if I plug the DC adapter it has a power indecator I have Check any short but no luck.
    If any suggestion you have will be helpful , thanks in advance
  • khaahk
    • Dec 2013
    • 819
    • Estonia
    Re: Nm-a272 cpu start to heat if plug power adapter
    What part of the cpu starts to heat?
    Does the cpu vcore power come up?
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      Yes ,Its present when I plug the ADAPTER but I have a short on the mother board but I cant find what it causing the short
      how can I find the short?
      • khaahk
        • Dec 2013
        • 819
        • Estonia
        How do know that you have a short?
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          i'VE CHECK THIS
          THERE SHORTED TO GROUND
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Remove them from mb and check out of circuit in diode mode for short-that will rest your doubt.
            • kalilinux25
              • Mar 2018
              • 2093
              • ZAMBOANGA SIBUGAY
              Those the short cause the cpu to heat ?
              • khaahk
                • Dec 2013
                • 819
                • Estonia
                From the picture it is unclear where the short is. Red circles are around capacitors, those?
                What do you call a short? How many ohms?
                Low ohms readings on cpu vcore are normal.
                • kalilinux25
                  • Mar 2018
                  • 2093
                  • ZAMBOANGA SIBUGAY
                  When I use diode mode It beeps on both side
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    As khaak has said, its very true that there exists very low resistance eg 100ohms in vcore circuits, i too dont doubt anything wrong there. You can still try removing those 2 fets and test them out of circuit.
                    • kalilinux25
                      • Mar 2018
                      • 2093
                      • ZAMBOANGA SIBUGAY
                      The two mosfets are done testing and there fine no problem even though I remove the two mosfet I get short to ground in capacitor and the two mosfet traces
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3628
                        • slovakia
                        short is resistance under 3ohm
                        • kalilinux25
                          • Mar 2018
                          • 2093
                          • ZAMBOANGA SIBUGAY
                          Yes its definitely short
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3628
                            • slovakia
                            remove coil and check on what side is short. than just continue to locate it
