Samsung RV520 (main BA4-01608A Scala2_R) no video and no cpu_core
  • robgerr
    • Apr 2012
    • 70
    • Italy
    Re: Samsung RV520 (main BA4-01608A Scala2_R) no video and no cpu_core
    I tried to inject 1v on L5 and I have a maximum absorption of 0.80A and the only component that warms up a bit is pch
    • piernov
      • Jan 2016
      • 4439
      • France
      The PCH is supposed to heat when injecting voltage on its VCore line, but it doesn't exclude another component on the same line being partially shorted.
      (although it's still likely not the case)
      • robgerr
        • Apr 2012
        • 70
        • Italy
        i try to remove ethernet ic but short remain
        • robgerr
          • Apr 2012
          • 70
          • Italy
          pch replaced, now it does not overheat and I do not find the 3ohm on the L5 coil but 20 ohms (I think it's ok now). The defect remains that the machine turns on but I do not have the cpu_core yet. Any help guys?
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            Therefore, this laptop had got multiple problems. now check which power rail is not present other than cpu_core. If all others are present, check the cpu_core circuit to find a shorted point.
            • robgerr
              • Apr 2012
              • 70
              • Italy
              #26
              I think the problem has been solved. I left the laptop turned on for 20 minutes, after which the fan stopped and the iiamgine appeared in the external screen, obviously the CPU core was present. I turned off and on again and no image again. I heat the nec tokin and it's the laptop power up perfectly. Supposed nec tokin with 4 cap tantalio 330uf and it seems to work perfectly. I keep you on trial and let you know
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                #27
                A bad Nec Tokin again. replace it ASAP.
                  09-07-2024, 05:50 AM
                • Asraf Atb
                  Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                  by Asraf Atb
                  Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                  Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                  I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                  01-27-2025, 05:02 PM
                • JSin21
                  Compatibility of main boards between different variations of samsung MU6100
                  by JSin21
                  Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                  I have Samsung Smart TV UA65MU6100WXXY version DA01
                  Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                  11-27-2023, 04:54 AM
                • mrautom8
                  Samsung TV UN75H6350AFXZC main board schematics?
                  by mrautom8
                  Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                  Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                  While relay is on, all voltage rails are present and steady (scoped) on main board.
                  I love a good logic puzzle but getting lost without any schematics.
                  No shorts on ANY capacitor main board.
                  Thermal camera shows 3.3V inductor getting warm instantly but...
                  10-19-2025, 06:32 PM
                • Yanleb
                  Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                  by Yanleb
                  Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                  If they are not compatible why did Samsung give them the same part number to begin with?
                  08-04-2025, 11:35 PM
