Q5wvh la-7912p
  • Prosatanosz
    • Nov 2015
    • 108
    • Hungary
    Q5wvh la-7912p
    Hi!
    There is no voltage on PC255 / PC256 Cpu power. Anything else seems to be ok. Nothing short, nothing hot, try start, 4 times. No display. Cpu replaced no change.
    Any idea? Bios possible?
    Thx
  • Prosatanosz
    • Nov 2015
    • 108
    • Hungary
    Re: Q5wvh la-7912p
    Sorry, not cpu power, but +vgfx_core missing
    • piernov
      • Jan 2016
      • 4435
      • France
      Re: Q5wvh la-7912p
      Yes try BIOS.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Re: Q5wvh la-7912p
        Check Dram reset signal on PIN30 of ram slot. Should be 1.5v. Check its present or not but first as peirnov has suggested flash bios.
        • Prosatanosz
          • Nov 2015
          • 108
          • Hungary
          Re: Q5wvh la-7912p
          Was bios...
          Thx
          • ronelex
            • Oct 2016
            • 195
            • Philippines
            Re: Q5wvh la-7912p
            Any one have good bios of it? i am working with a missing +vgfx_core
            • uintptr
              Acer E1-571G Q5WVH LA-7912P Rev 1.0 Bypass Touchpad Requirement
              by uintptr
              Hello, i have Q5WVH LA-7912P Rev 1.0 motherboard on my old PC. I accidently broke the touchpad things when replacing the back and up case. After doing that my motherboard going to blinking orange light on LED2. When I properly seat that touchpad thing, it occasionally boots. I think the problem is because of this. I don't have a soldering iron, so I can't solder it there. Since I'm going to use the computer as a server, I don't need a touchpad. I'm also leaving a photo for better understanding. I need to short-circuit it and make it work all the time. Which pins is for short-circuit? Thank you....
              01-02-2025, 09:36 AM
            • ohren
              by ohren
              09-08-2023, 05:24 PM
            • evilkitty
              Any idea what happened (wifi acted up)
              by evilkitty
              I have 2 access points, one a U6-LR and WZR-300HP running DD-WRT v3.0-r28444 (has had stable wifi since 2015)
              and i am trying to work on my PICO W and it suddenly would not connect and my computer had a very hard time connecting and my dad had been complained about his phone connecting
              so i ran a wifi scan script on the pico and it just hang for several seconds and found nothing, normally it would spit out every AP in under a second (both of mine and some neighbors)
              What i did was just install a U6-Lite that i had not gotten around to installing to replace...
              09-01-2023, 12:27 PM
            • karwan212
              Lenovo idea pad gaming 3, LA-L916P schematics request
              by karwan212
              Hi, Anyone have LA-L916P schematics, Please Share. Thank you!
              Today, 01:51 AM
              Alexia thermostat is this a good idea for for controlling your air conditioning system feedback wanted
              by sam_sam_sam
              My wife is asking me about getting one because our electric bill was that it has ever been even more than last year at this time nothing has really changed since last year last month unless the electric company has done some fuel adjustment charges I have not done any investigation into yet but I might have to but there was a time back a few years ago that I use to set the temperature warm during the day when we were not home but when we got wooden floors in our house and you have to keep the humidity down to keep it from warping I just set to a temperature to 75*F to keep the humidity down but...
              06-22-2025, 10:23 AM
