A1278 wifi card cable wrong side connection
  • terryhoho
    • May 2014
    • 5
    • singapore
    this is so awful, my friend had a macbook pro, the wifi is the small chip under the screen cover, he connect the cable to wifi card in the wrong side. causing L3404 to burnt. which, now the device able to boot & use, able to use USB,experiencing no wifi detect.
    below test under a working screen assembly,
    i replace a good L3404, 5v back, but it will cause the system to white screen, no boot.
    USB mouse light will flash once then no light, but there's 5v on USB ,L4605,L4615.
    i removed U3440 , while L3404 is there, the white screen persist.
    most of the lines on J3401 are connected to U1400.
    a1278 820-2879-B
    im thinking if anyone have same experience before or schematic for the wifi chip?
    attached is the boardview and schematic for the board
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • alegatorul
    Cello Tv . wifi 40" board HK.T.RT2841P638 wrong file update
    by alegatorul
    hi,
    i've being using this Cello tv, uk brand, C40rts, HK.T.RT2841P638 main board, for a year or more.
    Last week i've found an update, 3rd party, that i though it was close to my board. Inserted on a usb stick the install.img, started the Firmware update, ended, rebooted and nothing. The led (red-green) keeps flashing, backlight is on but to response on remote.
    I've retried with original fw, no success. Hooked the uart Cp2102, putty, tried to swuu command (to update from usb), it goes for a while the get "cpu reset" on laptop screen that brakes the process and halt....
    11-03-2024, 02:28 AM
  • howardc64
    M557-G0 no WiFi/Bt no WIFIVendor file?
    by howardc64
    Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
    • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
    • Service Menu shows many Bt/Wifi info missing
    • Vizio app shows no WIFIVendor file
    Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
    • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
    10-15-2024, 01:12 PM
  • ugamazing
    820-00850 & 820-01949, No WiFi *In Recovery*
    by ugamazing
    I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
    1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
    2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
    01-25-2023, 05:39 PM
  • AlexVG
    Replacing the WiFi module on a vacuum cleaner iROBOT i7
    by AlexVG
    I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
    I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
    (This board does not respond, only the LEDs light up in a circle.
    The liquid damage is catastrophic and restoration is impractical).
    (I bought this board to get the WiFi module and camera).
    The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
    If...
    10-22-2024, 07:20 AM
