MacBook Air 2015 (820-00165-A)
  • andrew_puma
    • Jul 2018
    • 14
    • moldova
    Hello, I need help. Brought to repair the macbook with the problem there is no way to install osx. The password from Efi was lost. In another service, the password was reset. But the serial numbers do not match the back cover. another dump is recorded. there is no native.
    The installation hangs.
    What to do?
    sorry for my bad english
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: MacBook Air 2015 (820-00165-A)
    The BIOS got fucked with. Try to get the original dump. You need the original ME region for it to work properly.
    You could try to put a clean ME but it's known to cause issues sometimes on Macbooks.
    • andrew_puma
      • Jul 2018
      • 14
      • moldova
      There is no original dump. Filled dump with pure ME. But without result. the installation also does not start.
      Can you check my dump that I wrote down?
        • 21841
        Try the Blank Board Serialiser to program a new serial.
        https://www.dropbox.com/s/t6i9bzn165...lizer.zip?dl=0
        • andrew_puma
          • Jul 2018
          • 14
          • moldova
          ok thanks, I'll try
          • andrew_puma
            • Jul 2018
            • 14
            • moldova
            https://a.**********/a12/1807/df/36649a84441c.jpg
            • andrew_puma
              • Jul 2018
              • 14
              • moldova
              Does not start
                • 21841
                A few more bios dumps for you to try .
                • andrew_puma
                  • Jul 2018
                  • 14
                  • moldova
                  ok thanks, I'll try
                  • danny_flo25
                    • Sep 2018
                    • romania
                    i have the same problem as you ,did you fix it ?
                    or someone else
                    • bryanpoints
                      • Aug 2017
                      • 56
                      • Philippines
                      need new dump sir 2019
                      820-00156-A
                      thanks more power badcaps
                      • Sergioz
                        • Apr 2016
                        • 12
                        • New Zealand
                        Try to look for small components with tiny corrosion, especially on some mosfets. I had similar issues when Q8062 had corrosion on it. Had to replace it with the donor board component.
                        Also, although on different board, I had the similar issue with boot freezing on 820-3662, in that case I had to replace and rewire the Q1920 due to few pads being ripped off.
                        • MAK_US1977
                          • Jul 2020
                          • Egypt
                          Please I need new dump 2017 820-000156-A
                          • yura8
                            Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
                            by yura8
                            Hi there! I have not so usual situation...
                            I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
                            My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
                            P.S. If you have else any ideas about repair, or you had a similar...
                            12-20-2024, 02:31 PM
                          • twonk9098
                            Macbook Pro mid 2015 battery required to boot?
                            by twonk9098
                            I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                            The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                            This model has the newer trackpad which is not clickable when turned off.
                            At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                            If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                            12-10-2024, 06:51 PM
                          • kenzo2
                            Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
                            by kenzo2
                            I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
                            I need dump file MACBOOK PRO A2159
                            TSB4232(256)
                            TSB4229(256)
                            Thanks​
                            01-11-2025, 04:18 AM
                          • envym
                            by envym
                            Hi everyone!
                            06-27-2025, 08:54 AM
                            Apple MacBook Air 13" Early 2015 Service Guide
                            Apple MacBook Air 13" Early 2015 Service Guide...
                            10-15-2024, 02:06 AM
