How to find short: just want to share
  • Stevie2001
    • Apr 2018
    • 183
    • irland
    Connect gnd to ground.
    Test probe on + if it beeps then solder a wire and connect
    Dc power supply and inject 1v 050amps and increase.
    Some shorts maybe with other parts on board but you can use this same method.
    Use lighter petrol or freeze spray thermal camera works best
    For power faults only
    If the board is taking in voltage and no amps then use method above.
    Sometimes if you are on 19v and 0.0 amps increase a little bit till you se 1amp and fan will kick in on dc power supply.
    Share your methods
  • aaronkatrini
    Help me find the short circuit on this WORKING Nvidia GTX1650
    by aaronkatrini
    Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
    Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
    04-18-2024, 03:15 PM
  • snow_sg1
    MSI GS73 (MS-16K61) : help me find short (got thermal cam)
    by snow_sg1
    First : I've got a SMD rework station, thermal camera and good soldering station
    This is my first "short" motherboard repair, this laptop was 25€ so no loss, it just for learning. I want to learn how to fixed board because I want this to become my job.
    I've been fixing electronics for 15+ years, but mostly VCR and camcorder.
    So, I checked power adapter pin to ground, no short, then I plugged the charger in, light on charger blink indicating short.
    PQ19 mosfet got HOT straight away (viewed on thermal cam). Checked,...
    09-13-2024, 03:30 PM
  • DynaxSC
    Extreme High Current & Low Voltage Short Killer ??
    by DynaxSC
    Hi Folks
    I'm looking for a extreme high current short killer solution for a reasonable cost.
    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
    After taking off the socket, the shorts dissappear again.
    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
    10-15-2024, 10:13 AM
  • Mess
    Beginner question. Did I find a short?? HP dax31mb1aa0 REV A motherboard
    by Mess
    Hi beginner here, so I'm not sure of I've done this right 😅 trying to diagnose my laptop's motherboard (dax31mb1aa0 rev a). I don't quite know how to read the schematic, so I'm attaching the pictures of the motherboard and the measurements.
    I was attempting to measure resistance to GND on inductors. I disconnected motherboard and used "continuity testing" setting on my multimeter. I put black probe to Ground & red probe on an inductor. Did I measure this right? Am I correct to think that 0.3 ohm measurement indicates a short circuit? Thank you for your help!...
    09-15-2024, 09:56 AM
  • gugutm
    a1989 820-00850 stuck at 5v 0.041a Help
    by gugutm
    I'm new to the forum,sorry english is not my first language too, i got a basic plus knowledge, but now i am in this situation where i need some help , i spend good few days reading forums , here and outside , to help my problem solve, with no luck
    long story short, i bought macbook pro a1989 820-00850, clean no water damage which was stuck on 5v 0.200/300a i read a lot of forums what that could be , it indicated to faulty corrupted t2 rom
    of course before jumping to conclusion and connected to DFU , i believe i done basic checks...
    01-04-2025, 09:35 AM
