Asus x555ld rev 3.1
  • kokono
    • Jun 2018
    • 203
    Asus x555ld rev 3.1
    i have this motherboard with All voltage
    power LED and charger led lighting and fan rotating
    all things ist ok but dont have screen
    i programmed two time Bios chip but nothings( i attached two file and original bios)
    CPU i7 4510U
    Geforce 820M
    any idea ?
    • 21936
    Re: Asus x555ld rev 3.1
    Try this bios .
    • kokono
      • Jun 2018
      • 203
      i done
      nothings
        • 21936
        Sometimes the soldered RAM goes bad on asus boards.Whats your motherboard part number
        • kokono
          • Jun 2018
          • 203
          yes, i think onboard RAM ist problem
          but do you know how i can disable onboard RAM for REV 3.1 ?
          • kokono
            • Jun 2018
            • 203
            Today i changed four jumber in this video and again not happen
            https://www.youtube.com/watch?v=CAfV43L0tco
            i tested many version bios and tested without onboard ram
            unsuccessful
            EDIT: maybe this video not good for REV 3.1
            i checked "H_CPUPWRGD" signal and ist ok .
            • kokono
              • Jun 2018
              • 203
              maybe i have problem with graphic chip or graphic memory ?
              how i can disable GeForce graphic and test with intel onboard graphic ?
              • cacla
                • Apr 2015
                • 444
                Pls sent me sn form you model and i will find your dump in asus system
                • kokono
                  • Jun 2018
                  • 203
                  F1n0cv31738503f
                  • cacla
                    • Apr 2015
                    • 444
                    By sn. this is your dump
                    • kokono
                      • Jun 2018
                      • 203
                      thx for your time
                      afternoon i can test, i hope work
                      • kokono
                        • Jun 2018
                        • 203
                        i tested, ist same
                        do you have another bios ? or any idea ?
                        all things ist ok but dont have picture
                        • kokono
                          • Jun 2018
                          • 203
                          YEEEEEEEEEEEEEEEEEEEEES
                          YEEEEEEEEEEEEEEEEEEEEEES
                          YEEEEEEEEEEEEEEEEEEEEEEES
                          DONE
                          Thx All
                          • tibimakai
                            • Jan 2012
                            • 3680
                            What exactly you have done?
                            I don't understand from those pictures.
                            • kokono
                              • Jun 2018
                              • 203
                              I had an oxidation and eventually a signal breakdown
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Aha, it was a simple fix, but hard to find. Maybe I should look over my board as well.
                                Congrats!!
                                • kokono
                                  • Jun 2018
                                  • 203
                                  Congrats!!
                                  Yes, please check your board, maybe also your problem ist a small hardware problem
                                  • Raziel
                                    • Jul 2018
                                    • 11
                                    • Italia
                                    Hi, i have a problem with Asus x555ld ver. 3.1
                                    The tension of 3V Backlight panel on/off in the pin 21 of Analogix ANX1121 is down.
                                    Help please
                                    • Raziel
                                      • Jul 2018
                                      • 11
                                      • Italia
                                      Picture of Analogix 1121
                                      • piernov
                                        • Jan 2016
                                        • 4439
                                        • France
                                        What's the voltage on all pins of this diode?
