DAX1BDMB6F0 Power Issue
  • dalejg
    • 10
    Re: DAX1BDMB6F0 Power Issue
    Well, after a couple of hours the orange light changed to the white light whilst plugged in. I tried to start it but no luck. The light went out as I pressed the button.
    Now when i plug it I get nothing. Will try again tomorrow. Thanks for the advice.
    • Pierre-Yves
      • Jun 2018
      • 28
      Hi - Again, do this while the computer is unplugged and on battery power only or you will be wasting your time...
      • dalejg
        • 10
        Will do thanks
        • dalejg
          • 10
          I have tried what you have said for the last few days abd still nothing.
          I tested a few things on the motherboard and the big capacitors and the small ones around them when tested on continuity are all short to ground on both sides of the capacitors.
          From what I have read they should not be short on both sides.
          • dalejg
            • 10
            https://ibb.co/hBm36FJ
            • dalejg
              • 10
              Thanks for your help, but after trying everything you said several times over a couple of weeks and it still will not work. So looks as though I either replace the motherboard or find someone who has experience of repairing rhe motherboard.
              • dalejg
                • 10
                I had given up with my laptop, but for some reason today I pulled it out plugged it in as the battery was totally flat. The light came on orange and I pressed the power button and the laptop sprung back into life. I was totally shocked!!!!
                It did say the cmos had been reset, and to press enter to continue but all is working at the moment. I think I will just leave it on from now on. Not sure I want to shut it down again.
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • justice171
                  Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                  by justice171
                  I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                  Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                  1. Verified that all critical voltages are present:
                    • 3.3V and 5V are always present if DC is plugged.
                    • 1.8V on the BIOS chip is present.
                  2. Checked the power button functionality:
                    • When pressed, the voltage drops to 0V, indicating the button is functional.
                  3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                    • Confirmed connectivity is intact, ruling out issues
                  11-26-2024, 12:39 AM
                • claws77
                  lenovo flex 5 14itl05 power sequence issue
                  by claws77
                  hi guys, my motherboard will not start no matter what
                  when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                  but rest nothing happens no sign of life.
                  this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                  with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                  but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                  i have no knowledge of motherboards ....
                  10-20-2024, 02:48 PM
                • yaya3gmax
                  Laptop Power Issue – Works on Battery, Fails on Adapter Load
                  by yaya3gmax
                  Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                  Symptoms:
                  • Laptop works normally on a pre-charged battery.
                  • Battery does not charge when adapter is connected.
                  • Without battery:
                    • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                    • Speakers “pop” when power cut occurs indicating harsh sutdown.
                    • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                  08-21-2025, 07:16 AM
                • SuperJames
                  Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                  by SuperJames
                  This one's a weird one, and still unsolved despite it having gone back to Dell once.
                  Specs
                  i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                  Backstory
                  I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                  10-23-2023, 04:09 PM
