Vostro 3560 (LA-8241P, UMA version) runs only on AC
  • spleenharvester
    • Mar 2010
    • 903
    Another LA-8241P here - not the usual shorted cap issue. (EDIT title is incorrect, board runs only on battery)
    On AC: Completely dead, 19V into VIN but nothing on B+. Adaptor does not trip and there is no evidence of shorts. There are 40ohms ish across PQ100 (legs 1-3 to 5-8) see attached image for voltage readings.
    On battery or if injecting 11V into B+: Board fires up with 2.8V at the power button, shuts down after 2 seconds (I suspect there's a second fault but we'll cross that bridge when we get there).
    Annoyingly the other LA-8241P I'm working on are not currently with me so I have no other boards to compare to.
    Any ideas?
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 903
    Re: Vostro 3560 (LA-8241P, UMA version) runs only on AC
    Update, there is 0.1V on pin 22 of PU100 (ISL88731CHRTZ-T). If I inject 19V into this pin, I get 19V on B+, so I suspect the IC is probably okay.
    Which I think narrows it down to PC111 or PR109.
    • khaahk
      • Dec 2013
      • 779
      • Estonia
      I admire that you put it in writing rather than checking both of them right away. I would not have the patience to do that...
      • spleenharvester
        • Mar 2010
        • 903
        The problem is that nothing on this board is screenprinted so I'm actually having serious trouble finding the components!
        The previous post was actually a fairly large measurement error though, pin 22 is actually getting 19V from VIN, so the problem is elsewhere (what I thought was PC111 was actually PC135, so I was injecting at BST_CHGA).
        • pyry
          • Dec 2015
          • 37
          • Mexico
          first test PC101 is not short and if not
          remove PQ103 and test if it turns on
          • khaahk
            • Dec 2013
            • 779
            • Estonia
            PQ100 is on my suspect list.
            • pyry
              • Dec 2015
              • 37
              • Mexico
              never mind my fault i mean PQ105B it's not doing his job
              • piernov
                • Jan 2016
                • 4435
                • France
                40 ohms across PQ100 seems too low to me. Check PQ100 and PQ101 out of circuit. (resitance between drain-source, drain-gate and source-gate)
                • spleenharvester
                  • Mar 2010
                  • 903
                  PC101 confirmed not shorted. I will check PQ100 and PQ103 when my new hot air station gets here.
                  PQ105 is getting 2.5V on legs 2 and 5 (as per leg 1 PQ109) but 0V on legs 1, 3, 4, 6. Is this normal (I'm not understanding very well what this circuit is supposed to be doing?)
                  I suspect PQ100 might be okay as when 5V is applied across source to drain, it seems to open normally and not heat up too much, just like PQ101 does. But I will make sure to test it out of circuit.
                  • spleenharvester
                    • Mar 2010
                    • 903
                    Is it normal to get the battery voltage coming up at the DC jack when only battery is plugged in and no adapter?
                    I tried to take a resistance reading between PQ105 and VIN on a pin that is usually 0V and got a massive spark for reasons that are not clear to me. The board behaves as it did before but I never checked whether the batt voltage came up at DC before, I am just wondering whether I killed something.
                    • BlueMidnight
                      • Jan 2015
                      • 489
                      The input FETs (PQ100/PQ101) are turned on by allowing current to flow through PR101 and PR105 to ground. This is a voltage divider that will place ~8V on the FET gates. When the gates are at 19V, the FETs are biased off.
                      The gates normally rise to 19V if PQ103 is turned on (shorting the gates to 19V directly) and/or PQ105B is turned off (disconnecting the voltage divider from ground and raising all points to 19V as a result). In reality, the board will always toggle both of those transistors at the same time. PQ103 is important as it very firmly holds the FETs turned off by shorting the sources and gates together. PQ105B helps a bit as well by switching off, but also saves a tiny bit of power.
                      On your board, the voltages on PQ103 show it is biased off. Likewise, the voltages on PQ105B show it is biased on. So, there really shouldn't be 19V on the gates of the input FETs.
                      Therefore, there must be a failed component causing a short between VIN/P2 and the FET gates (assuming no conductive residue on the board, etc). The most likely candidates are PQ100, PQ101, PQ103, or PC101. And, of course, all these have been mentioned already. Resistors don't really fail shorted unless there are carbon marks around them from them burning up or some such, so those are probably safe to ignore unless you get truly desperate.
                      To get a feel for the proper operation of that circuit, I've attached two pictures. Each shows a different scenario. One is with a good AC adapter connected. The other is with an AC adapter that is outputting a voltage that is slightly too low. Several other scenarios are possible of course.
                      That spark you saw could only occur if the circuit was powered (either by being plugged in or by there still being capacitors charged in the circuit). You should never measure resistance on a powered circuit. Also, even when measuring voltage rather than resistance, sometimes it's possible to slip and bridge a couple pins with the multimeter probe. That will also cause a spark and possible damage to the circuit.
                      And regarding the battery voltage being present at the DC jack... that is not normal...
                      Motherboards typically have 2 input FETs. All FETs have a body diode that will pass current in one direction even when the FET is turned off. By placing 2 FETs back-to-back so that their body diodes face opposite directions, this blocks current flow both ways.
                      The FET with the body diode facing in such a way that it block the AC adapter current is called the adapter input FET (ACFET). The other FET blocks battery voltage from feeding back to the DC jack (and into the AC adapter if it is plugged into the jack but not the wall outlet) and is called the reverse blocking FET (RBFET). On your board PQ101 is the ACFET and PQ100 is the RBFET.
                      PQ100 being shorted would explain all the symptoms. So that would be the first component you should remove and test.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        The best explanation a techie can make. Great
                        • spleenharvester
                          • Mar 2010
                          • 903
                          That is a superb explanation, thank you! I will test PQ100 as soon as my new equipment gets here.
                          Also I didn't know that about testing resistance while the circuit was powered - that would explain why my multimeter was freaking out a bit beforehand. I might also replace PQ105 while I'm at it just to be on the safe side.
                            DELL Vostro 3568 Notebook 3560 Specification for Upgrade or Repair
                            This specification for the DELL Vostro 3568 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3568 boardview and 3568 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3568 Notebook...
                            09-06-2024, 06:00 AM
                            DELL Vostro 3268 Vostro 3200 i3-7100 Specification for Upgrade or Repair
                            This specification for the DELL Vostro 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3268 boardview and Vostro 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                            09-12-2024, 03:44 PM
                            DELL Vostro 3268 Vostro 3200 i5-7400 Specification for Upgrade or Repair
                            DELL Vostro 3470 Vostro 3400 i5-9400 Specification for Upgrade or Repair
                            This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                            DELL Vostro 3667 Vostro 3600 i3-6100 Specification for Upgrade or Repair
                            This specification for the DELL Vostro 3667 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3667 boardview and Vostro 3667 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
