Hp 840 g4 elitebook Liquid damage
  • appie1206
    • Oct 2016
    • 127
    • netherlands
    Hello everyone i have a problem with my hp..
    It has liquid damage.... When i plug in the powercord the powerbutton will light up for a seccond.. when i press the power the power/chargeled will blink 9 times
    Can somebody help me with the schematic?... So i can checkthe voltage of some components!!..Or does some one knows how too fix?
    Thank you very much!!!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Hp 840 g4 elitebook Liquid damage
    Strip it down and see which areas have been damaged.
    Check for resistance to ground on the coils to check for shorts.
    Apply adapter and measure for voltages.
    • maverick8
      HP EliteBook 820 G4 - liquid damage - help
      by maverick8
      Hi
      I just got a HP EliteBook 820 G4 HSN-I01C 6050A2854201-MB-A01 i5-7200U with liquid damage. At the first check, the motherboard was short with no led light! After checking the motherboard I found a fired chip indicated in Area#1. After cleaning it, the short from the motherboard disappeared and the led light was presented, but not power on!
      After second checking with 19,5V presented on the board I found a chip very hot indicated in Area#2 as needing to be replaced.
      Can someone help me with a schematic for this HP? Or maybe some one help to find out...
      02-22-2023, 11:03 AM
    • Zibbo
      HP Elitebook X360 1030 G2 No backlight after liquid damage
      by Zibbo
      Hi, I have a HP Elitebook X360 1030 G2 OLDMAN-6050A2848001-MB-A01 laptop motherboard without backlight after liquid damage on the LVDS connector. The screen and LVDS cable are working.
      I have replaced the connector and its properly soldered, there is 19V on backlight supply pins.
      I need help identifying Backlight PWM and Enable pins on this motherboard....
      12-23-2022, 09:18 AM
    • av4x
      Fujitsu U7511 liquid damage, wont turn on anymore, does not respond to charger in any way.
      by av4x
      Good morning, everyone!
      I've gotten my hands on a few laptops with various defects because I want to get more involved in repairing electronics.
      First up is a Fujitsu Lifebook U7511.
      It won't turn on anymore and doesn't respond in any way when you plug in a power adapter.
      Model: Fujitsu Lifebook U7511
      CPU: Intel Core i5-1135G7
      GPU: Intel Iris Xe Graphics
      RAM: 16GB DDR4 - 3,200 MHz
      PCB manufacturer: ASKPCB?
      PCB serial numbers: CP801602, CP7984241-Z4, E239218, CP809978-01
      Damage: Liquid damage
      The liquid probably...
      Today, 03:09 AM
    • rounin
      MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
      by rounin
      Device Information
      • Model: MacBook Pro 14” M1 Pro (A2442)
      • Logic board number: 820-02443-05
      Original Issue
      The device suffered liquid damage, causing a short circuit on the logic board.
      Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
      Work Performed
      Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
      Current Status
      • When powered on, the screen shows support.apple.com/mac/restore....
      10-20-2025, 11:15 PM
    • mon2
      A1466 Macbook Air (Liquid damage repair)
      by mon2
      Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
      Macbook AIR Model A1466 Diagnostic 09-01-2021
      Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
      Problems & Resolutions
      1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
      09-01-2021, 09:31 AM
