hp 2530p hdd no detected
  • akande
    • Dec 2017
    • 278
    • Nigeria
    my hp2530p cannot detect hard drive, news hdd changed with cable no luck
    need someone help on this pls
  • EvazX
    ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
    by EvazX
    I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
    Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
    For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
    However, after some time, the replacement motherboard...
    08-25-2025, 06:09 PM
  • spacez
    XPS 15 9520 - tpm device is not detected - NO ssd detected
    by spacez
    I have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
    Service Tag: J2MSHW3
    |Express Service Code: 41518077843
    mother board LA-L402P REV 1.0(A00)​...
    08-18-2024, 10:54 PM
  • Nikan.e
    Inno 3d RTX2070 not detected - no I²C connection
    by Nikan.e
    Greetings and Salutations!
    I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
    The faulty DrMOS was removed, and the burned PCB area was milled away.
    All voltages are now good, but the GPU is not being detected.
    I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
    I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
    I thought these pins were used for communication during startup?!?
    On all...
    03-30-2025, 07:21 AM
  • superdota2
    HP 15s-FQ2552TU nvme drive not detected
    by superdota2
    HP 15s-FQ2552TU
    da0p5hmb8f1 rev f
    sn# 5CD138CCH4
    problem is power on but no display,no bios post
    i search bios here ,i found and it work and got display.
    https://www.badcaps.net/forum/showthread.php?t=104925
    second problem is nvme drive not detected in bios intel rapid storage,
    i tried a working nvme drive but still not detected in bios,
    also tried install system and install intel rapid driver,still not detected....
    06-21-2023, 09:36 PM
  • piernov
    NVidia bumpgate
    by piernov
    Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
    Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
    May complete this post at a later date with more details.
    Basically issue is a combination of thermal dissipation of the chip with hotspot,...
    03-27-2021, 10:34 AM
