i have this lenovo thinkpad and i want to connect the charger directly to motherboard.i connected it only the + positive and - negative but it says unknown charger and then shutdown
Lenovo E555
Re: Lenovo E555
These notebooks have an ID pin, but it doesn't go to a serial chip in the AC adapter like some do (e.g. Dell). Instead, there is a resistor between the ID pin and ground inside the plug. The value of the resistor indicates the wattage of the AC adapter. There is no ID wire needed between the plug and the body of the AC Adapter, and so if you cut open the cable, there will only be 2 wires.
Check out this page for likely resistance value required.
Looks like you probably need at least a 280 ohm resistor between the ID pin and ground to indicate an AC adapter of at least 65W.Comment
Re: Lenovo E555
If the resistor is the same value as the one in the plug, and the AC adapter supplies the right voltage, and everything is connected to the correct pins, then the problem must be elsewhere.
I don't have a schematic for that board. But if it is like the other ones, it uses the resistor in the plug as the bottom resistor in a resistor divider between 3V and ground. Measure the voltage on the ID pin and make sure it is not 0V or 3V. it should be somewhere in between.Comment
Re: Lenovo E555
I already explained why the cord has only 2 wires. There is a resistor inside the charger plug (the one you cut off).
The DC jack has 5 pins. 2 are power, 2 are ground, and the middle one is the ID pin. You must attach a resistor between the ID pin and ground. It must be the correct value (280 ohms for a 65W charger, or 550 ohms for a 90W charger).
With the resistor in place, the voltage on the ID pin must be above 0V and below 3V (probably 0.65V with a 280 ohm resistor, or 1.27V with a 550 ohm resistor).
We must know what resistor you used and what voltage you measure on the ID pin. There is nothing else that can be done until you confirm those things.Comment
Re: Lenovo E555
Hmm 40W is an odd value. I can find 45W and 65W chargers for some E555s, but not 40W. Though there are some 40W chargers for the Yoga series. In any case, there's no way the resistor will burn if connected between the ID pin and ground (unless something is quite wrong with the board). However, it will definitely burn if it somehow gets connected between 19V/20V and ground.
The 5 pins on the DC jack are:
(1) Ground
(2) Power (19V-20V)
(3) ID
(4) Power (19V-20V)
(5) Ground
The resistor goes between pin 3 and ground. Ground can be pin 1 or pin 5 or any other nearby ground point. Before attaching the resistor, there should be 3V on the ID pin. After attaching the resistor, there should be somewhere around 0.4VComment
Re: Lenovo E555
That's not correct. What are the voltages on the 5 DC jack pins without the resistor connected?Comment
by motormayhemLaptop Question
I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when... -
by flat-eartherI have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
So the battery is backfeeding the charger and being drained.
How can I prevent... -
Hi everyone.
First, let me preface by saying that I do not have much experience with diagnosing damages in motherboards other than visual inspection and checking simple short to ground faults.
But I do learn quickly, and really want to learn how to properly diagnose motherboard faults. If someone could have the patience to go over this board with me, it would be greatly appreciated.
A customer came into my shop with a A2179 MacBook with an 820-01958-A logic board. The reason for bringing the laptop in is that the laptop stopped turning on.
First thing...02-15-2024, 05:30 PM -
by mshoneSorry if topic if misplaced. Have lenovo thinkpad P1 gen2 with Xeon E-2276M CPU and NVIDIA® Quadro® T1000. It is a new board replaced. Old board was P1 G1 model with i7 and it is defective. I ordered a new one with xeon, but is gen 2. Laptop case is suitable for this motherboard, with some little difference (GPU fan and subcard).Ok, ordered and replaced and GPU fan and subcard and now laptop is working fine, but serial number and UUID is unknown. Ok, i readed several topics here and found Thinkpad maintenance disk, but.....which values to type? How to find data base with those values? serial...
Channel: BIOS Requests ONLY!
Today, 06:41 AM -
by code shareHi everyone,
I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
Here's what I've tried so far:- Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
- Booted successfully on AC power only with the battery disconnected
- Visual inspection of the battery — no swelling, burn marks, or connector damage
- Battery
- Loading...
