Samsung RV510 shuts off 5 to 8 minutes
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Hi everyone!I need help on this samsung RV510 MODEL:SCALA-15UL BA41-01322A REV MP 1.0. The problem is laptop shuts off after 5 to 8minutes.Could it be a me region problem for this?or does anyone have a good working dump for this please help!I have already tried replaced nec capacitor with tantalum caps, replaced cpu and ram but the same issue shuts off at 5 to 8 minutes.
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Samsung RV510 shuts off 5 to 8 minutes
    Anyone please help
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      upload the original bios here. Then, other technicians will clean it for you.
      • String2016
        • Nov 2015
        • 2238
        • philippines
        Ok thanks for the response here is the original dump shutdown from 5 to 8 minutes.Can someone clean the me region for this please!
        • String2016
          • Nov 2015
          • 2238
          • philippines
          anyone please help on this please
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            are you sure that this is a good dump? looks strange
            what is the cpu on this one?
            i cand find any trace of ME reginon inside but here is few dumps found on net
            doono will it work
            Im Back... sort of...
            • String2016
              • Nov 2015
              • 2238
              • philippines
              yes i pulled out the chip and read it on programmer backup.as for the history of the client said laptop stack for years never been repaired before.the CPU intel pentium T4500
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                i edited previous post, see atachments
                this is pre HM55 (maybe i40 or i45 series chipset) and it does not use ME region, that started from HM55 and up
                try dumps but it is likely that its a hardware problem
                check with another power brick, cpu, cpu cooler, see sensor for temp or something...
                hope it helps
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  thanks for the response it has MCH INTEL 82GL40
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    yes, gl40 and gl45 does not use ME region, look elsewhere
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      maybe this is a bios issue because when i used original dump it boots fine but only shut down 5 to 8 minutes i already replaced the cpu with the same cpu but still the same problem.
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        try attachments in post #6 and see does it work
                        • String2016
                          • Nov 2015
                          • 2238
                          • philippines
                          ok thanks ill try to flash the bios with post #6 and post results later
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            i flashed the bios with post #6 file the same issues it goes off 5-8 minutes.could it be the MCH is the problem?
                            • String2016
                              • Nov 2015
                              • 2238
                              • philippines
                              i have attached the image on the CPU and MCH,When i tried to reformat the laptop its stuck at 18percent then shuts off. I noticed there is a slot for another power supply ceramic caps could i try to add another ceramic caps on the one marked red?
                              • caspian
                                • Oct 2015
                                • 1591
                                • Laptop
                                If there was no capacitor there, there is no need to add one. Does any IC get hot near the CPU and the MCH?
                                • ala_borbe
                                  aka Donald
                                  • 1625
                                  • Malta
                                  Does it happen that this borad have nec/tokin cap like toshiba a300/l300?
                                  • Dumah Brazorf
                                    • Jun 2013
                                    • 179
                                    • Italy
                                    So, how about temperatures?
                                    Does it shutdown even in the bios page? If you restart it immediately after a shutdown does it work for another 5-8mins?
                                    • String2016
                                      • Nov 2015
                                      • 2238
                                      • philippines
                                      even on the bios page it shuts off it it restart it does not work for 5-8mins. the hot component only is the MCH and this intel chip IntelĀ® 82801IBM
                                      • String2016
                                        • Nov 2015
                                        • 2238
                                        • philippines
                                        and now it shuts off 1 minute. does this MCH is the problem?
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
