Acer 7720ZG disable 3d card
  • nels
    • Oct 2015
    • 14
    • france
    hi all,
    i have a acer 7720zg the 3d nvidia card is dead ,this model have a intel graphic chip too.
    any one know the way to activate intel card ?
    i have removed the nvidia card and got blank screen ...
    thanks
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Acer 7720ZG disable 3d card
    It will help if you find the schematics file of this mainboard. Then, upload it here.
    • nels
      • Oct 2015
      • 14
      • france
      hi caspian,
      thanks for reply ,unfortunately i haven't found it,if some one ...
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        what is the mainboard code?
        • nels
          • Oct 2015
          • 14
          • france
          Icl50 la-3551p
          rev 3.0
          i found this:
          https://www.informaticanapoli.it/dow...l_LA-3551P.pdf
          • nels
            • Oct 2015
            • 14
            • france
            in page 10 ,i read "change to 0hms to use PM chip" i found the resistors in motherboard do you think if i short the resistors i got it working ?
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              No, it will not work. Find RP3 and RP4 on the mainboard. Then, tell which one exists there.
              • nels
                • Oct 2015
                • 14
                • france
                RP4 exist ,RP3 nothing
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  It seems conversion of this mainboard to UMA is either not possible or it takes too much work and troubles. Thus, it would be better if you buy a cheap MXM graphics card or scrap the laptop.
                  • nels
                    • Oct 2015
                    • 14
                    • france
                    ok thanks for help
                    • ramkaskad12
                      acer predator g9 593 (mu5dc/ch7dc) rev 2.0 disable the video card
                      by ramkaskad12
                      acer predator g9 593 (mu5dc/ch7dc) rev 2.0 help me disable the video card on this laptop
                      08-14-2023, 01:46 AM
                    • mat2k
                      Disable faulty soldered RAM on Acer A315-22
                      by mat2k
                      Hello, I've been googling for some pointers on this but couldn't find anything that applies to this board. I have an Acer A315-22 (board NB8607) with faulty RAM between 142 and 174mb. I just wanted to disable the onboard RAM altogether, but this one doesn't seem to have any memory down ID resistors or strap in order to disable it. I'm attaching the schematic I found, the boardview for it also seems to be available somewhere in this forum but I still don't have a use for it lol.
                      How would I disable the RAM on this PC? Thanks for the help.
                      [MOD EDIT] LINK to boardview + schem...
                      06-02-2024, 11:26 AM
                      09-06-2024, 05:27 AM
                    • bbenalmadena
                      Old Sony VAIO da0hk5mb SVE1512E1E disable Radeon video card
                      by bbenalmadena
                      I have a Sony VAIO SVE1512E1E (motherboard da0hk5mb) video card is broken, has artifacts, I want to disable it, the processor is an I3-3110M that supposedly has an integrated Intel GPU and I want to disable the onboard Radeon so that can be used.
                      I download some schematics, and tried to remove VPL1, but then the laptop starts some leds, and shut off. Should I try to lift VPL1 and VPR47 and pass a cable to one tip of VPR47 and the other back to VPU1 to see if that works or it is pointless?
                      That seems to be some feedback to VPU1 and I guess if it does not detect voltage, laptop...
                      08-30-2025, 10:40 AM
                    • b-slayer
                      Acer A317-53 need help to disable faulty onboard ram
                      by b-slayer
                      Hello.
                      I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                      - first one is to modify le bios to disable the onboard ram.
                      - second one is to disable the onboard ram by desoldering some components on the mainboard.
                      so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                      so i found that my motherboard...
                      10-12-2024, 03:46 AM
