Dell studio 1558 CMOS battery connection on motherboard damaged
  • raghava216
    • Feb 2018
    • 3
    • India
    My Dell studio 1558 did not boot up last night. So, I opened it up, took out the RAMs, cleaned and replaced them. Then, I felt that the CMOS battery might have gone bad. So, I attempted to take out the CMOS battery from its slot. But, unfortunately the case which is soldered to the motherboard came out at one end. The positive terminal of the battery is connected to two places through PCB tracks, 1 to a via and the other to one end of a resistor. These 2 tracks cut open when I tried to eject the battery. I wanted to connect a wire between the points after scratching out the PCB track. Unfortunately, while scratching the track, the track came out along with the conductor near the via. The other connection of battery positive to resistor is also difficult to solder with wire.
    Is there any way to fix this? Is there any other known point where I can wire the positive terminal from CMOS battery?
    My laptop is running but displays a message that CMOS checksum is bad, every time I boot. Of course, the time & date are lost after every reboot.
    Is it safe to work with my laptop in this condition?
    Kindly suggest solution.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5047
    • US
    Re: Dell studio 1558 CMOS battery connection on motherboard damaged
    I've had this happen before, I just unsoldered the whole battery holder, took one out of another motherboard and soldered it back in. Damagjng traces just makes things more difficult. Can you upload a picture of the area (bottom of pcb)
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5047
      • US
      Oh wait this is a laptop. In thay case give us a picture of the damaged area. Not sure id this is a smd cmos battery holder or not
      • gabik111
        ORD spotter
        • 142
        • USA / Poland
        Get the schematic diagram and look where the CMOS battery is connected then find better points on the motherboard to solder wires.
        Laptops and computers repair.
        • raghava216
          • Feb 2018
          • 3
          • India
          Sorry for the delay in my reply. Here's a picture of the damaged area before and after my misadventure. Tracks going near D25 and R597 from the battery positive terminal to be zoomed. Please do suggest a solution. Thanks.
          • jpyerry
            • 94
            I had the exact same thing happen to me (on the exact model laptop you have), I went to replace the battery and the holder broke off the board taking the trace with it.
            You could probably bodge a small wire in if you wanted to do so.
            Here is what I did to repair my board:
            I desoldered the existing SMD battery holder.
            I bought a new SMD CR2032 battery holder.
            I sourced some high purity, very thin copper foil.
            I cut out a new trace with an Exacto knife and a straight edge in roughly the same shape as the original trace.
            I carefully scraped a small section of the solder mask covering part of the un-torn off section of the trace to expose the underlying copper and added a small amount of solder to the exposed area.
            I then glued (using epoxy) the replacement trace into place making sure that the new trace overlapped the soldered section of the old trace.
            I then melted the solder so that the two trace were joined electrically.
            I painted over the copper foil (except the land for the new battery holder) with new solder mask.
            I allowed the new solder mask to cure (sunlight helped the process).
            I glued (using epoxy) the new battery holder in place to the board to lend some additional mechanical stability to the board.
            I finally soldered the contacts for the battery holder to the board.
            I popped a new CR2032 battery in.
            The board fired up and has worked just fine ever since.
            It was a colossal pain in the behind to do, what I did was probably overkill, but it worked well and I learned a little about repairing circuit traces.
            Good luck in whatever you wind up trying.
            I wish I had pictures, I ended up giving that particular laptop away about two years ago.
            This is why I really hate reworking surface mount technology and it is illustrative of their inherent weaknesses.
            All the best,
            jpyerry
              HP ZBook Studio G4 + DreamColor Z27x Studio Display Mobile workstation Studio Specification for Upgrade or Repair
              This specification for the HP ZBook Studio G4 + DreamColor Z27x Studio Display Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Studio G4 + DreamColor Z27x Studio Display boardview and Studio G4 + DreamColor Z27x Studio Display schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
              09-06-2024, 06:00 AM
              MSI Creator Z16 HX STUDIO B13VGTO-052 Notebook Z16 HX Studio Specification for Upgrade or Repair
              This specification for the MSI Creator Z16 HX STUDIO B13VGTO-052 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z16 HX STUDIO B13VGTO-052 boardview and Z16 HX STUDIO B13VGTO-052 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
              09-07-2024, 06:38 AM
              MSI Creator Z16HX STUDIO B13VFTO-053 Notebook Z16 HX Studio Specification for Upgrade or Repair
              This specification for the MSI Creator Z16HX STUDIO B13VFTO-053 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z16HX STUDIO B13VFTO-053 boardview and Z16HX STUDIO B13VFTO-053 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              MSI Creator Z16 HX STUDIO B13VGTO-051 Notebook Z16 HX Studio Specification for Upgrade or Repair
              This specification for the MSI Creator Z16 HX STUDIO B13VGTO-051 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z16 HX STUDIO B13VGTO-051 boardview and Z16 HX STUDIO B13VGTO-051 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
              HP ZBook Studio Studio G5 Mobile workstation Specification for Upgrade or Repair
              This specification for the HP ZBook Studio Studio G5 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Studio G5 boardview and Studio G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 08:23 AM
