Asus gl552vw touchpad not working...
+ More Options
Posts
  • myth77
    • Feb 2017
    • 380
    • Croatia
    The laptop works perfect except touchpad...i tried everything..asus smart gesture will not install...saying error preventing...it is not detected in device.manager...no touchpad..i even tried to change it for similar touchpad model of asus but also not working...i measure voltages and its powering fine...i dont know what else to do? There are many threads on the internet about this same model where touchpad is not working...the ribbon looks fine..i have continuity on each pad from beggining to the end of ribbon cable...
    Oh, i use win 10...anybody with some new ideas?
    One more thing i can not flash bios because low/bad battery, i tried with reprogramming bios but two dumps i found were not working...so i put the old back..
    Fn+f9 not working...every other fn function works.
    Thank you
  • rheyntau
    ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10
    by rheyntau
    CAN ANY ONE HELP ME WITH THIS PROBLEM....ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10 ..IT WAS ELAN TOUCHPAD..I DOWNLOAD A DRIVER BUT ITS NOT WORKING IT SAYS "WINDOWS FOUND DRIVERS FOR YOUR DEVICE BUT ENCOUNTERED ERROR.....THE HASH FOR THE FILE ISNOT PRESENT INTHE SPECIFIED CATALOG......."
    07-06-2025, 07:22 AM
  • jamesp
    Asus TP412FA keyboard and touchpad not functioning
    by jamesp
    Hello guys,
    need help, i have a laptop that i encountered having keyboard and touchpad not working, not immediately going to BIOS i already tried replacing even just the keyboard with a new one but still problem exists. now i only realized to checked it from bios to erase doubts. i found out both touchpad and keyboard are working only on BIOS but not on windows.
    since i cant just reformat the said laptop, i tried installing MyAsus utility and updated my drivers , and windows update as well. i included updating the bios to latest 3.08 version. still kb and touchpad is working on bios...
    08-18-2024, 11:02 AM
    ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
    This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
    09-07-2024, 02:50 AM
  • ShadowAi
    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
    by ShadowAi
    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
    03-15-2024, 10:46 AM
  • MotherTeresa
    ASUS ROG GL552VW v2 - BIOS check/repair
    by MotherTeresa
    Hello Could someone who knows about BIOS take a look at the attached dump. Laptop AUSU ROG GL552VW with nVidia N16P 4GB and i5 CPU.
    I used to change GPU in the laptop, and it worked without problems for a few years. My 9-year-old daughter uses the equipment, yesterday it worked, today she says it won't start. I checked and it hangs on the ASUS logo, you can't enter BIOS (it worked once).
    Disconnecting all peripherals, including the keyboard, resetting BIOS with jumpers under RAM, changing RAM does nothing, it still hangs on LOGO.
    I installed a different BIOS from this model to...
    06-29-2025, 07:30 AM
