Power Management input output Samsung SCALA3-17 REV:1.3
  • Techtiger
    • Oct 2014
    • 1602
    • france
    I have questions about Power Management input output IC if you have a blown out chip when replace it will the MB work normally or you have to flash it ?
    And what is the resaon to flash it ?
    need the schematic Samsung SCALA3-17 REV:1.3
    Still learning the Basic need help
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: Power Management input output Samsung SCALA3-17 REV:1.3
    if you refer to EC as ITE or Novuton or ENE etc, only few chip need
    to be programmed (in most cases lenovo) after replacing it, in some cases (asus) the process is automatic.
    The programmer (vertyanov, etc) is expensive for occasional use.
    • Techtiger
      • Oct 2014
      • 1602
      • france
      Yes Those are the IC i was referring EC as ITE or Novuton or ENE etc,
      Thanks 🙏🏿 Learn something
      jasko_jacker
        09-07-2024, 05:50 AM
      • FrancescoV
        Onkyo HT-R390 no sound output, video output ok
        by FrancescoV
        Good morning everyone,
        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
        The firmware reported is the following:
        M:1.00/11107BLP
        D:?.??/????????
        O:1.00/11107AL
        The DSP firmware given the question marks seems corrupt.
        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
        05-11-2025, 02:59 AM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
