asus x452c weird problem
  • String2016
    • Nov 2015
    • 2238
    • philippines
    hi everyone i have problem with this asus x452c laptop.The problem is if i insert flash drive on the usb port it boots normally to windows but if i removed the flash drive not inserted to usb ports and turn on the laptop,it directly go to bios setup.I already check the settings in the bios on boot device priority and hardrive first on the first boot.anyone can help me to solve this problem please
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: asus x452c weird problem
    does anyone encounter the same problem with this please need help.
    • String2016
      • Nov 2015
      • 2238
      • philippines
      problem solved for this the problem it was the keyboard i removed it and now works fine
      • lazaro.089
        Asus Zephyrus M16 / GU603ZW problem
        by lazaro.089
        Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
        CPU: Core i9-12900H
        Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
        Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
        The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
        08-26-2025, 06:33 PM
      • AtelierRepa
        ASUS X712JA problem
        by AtelierRepa
        I have a problem with the bios, let me explain.
        With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
        I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
        My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
        The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
        06-15-2024, 04:33 AM
      • lukkihapsi
        Asus Vivobook X515JA Weird Boot Issue
        by lukkihapsi
        Asus Vivobook X515JA Laptop
        Issue :
        Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
        Tried :
        Cleaned inside for dust, applied fresh thermal paste. No Change!
        Removed keyboard, Trackpad, fingerprint sensor. No Change!
        Removed Internal SSD. No Change!
        Updated BIOS to latest version. No Change!
        Removed battery and pressing power button for 1 minute. No Change!
        Weird Part :
        Upon turning laptop ON, screen lights up - stays black,
        I...
        07-07-2025, 12:07 PM
      • greg1985
        Asus dabkxmb18b0 rev.b bios problem
        by greg1985
        Hi. I bought a damaged Asus motherboard, model dabkxmb18b0 rev.b. The problem with the motherboard was a faulty processor.
        I replaced the processor, but it arrived without a BIOS chip. I found one post on the forum, but my problem is
        I don't know which chip to program, and I don't have a schematic. Does anyone know which BIOS chip models are compatible with this motherboard? If so, please let me know. Thanks.
        10-20-2025, 11:34 AM
      • boticario
        problem with asus tuf A17 FA707NUR
        by boticario
        I’m trying to recover an ASUS TUF Gaming A17 FA707NUR (Ryzen + RTX 4050, 2023 model).
        The laptop powers on, fans spin, but the dGPU (NVIDIA) is not properly initialized — sometimes it shows up in Device Manager with Code 43, sometimes black screen.
        After several BIOS downgrades/upgrades (versions 300, 301, 303) and EC resets, it thinking looks like the EC firmware (IT5570VG-256) might have a persistent fault or flag stored in flash.
        I already extracted the BIOS .CAP files and DXE sections with UEFITool and IFRExtractor, but I couldn’t find...
        10-18-2025, 04:37 PM
