hi everyone i have problem with this asus x452c laptop.The problem is if i insert flash drive on the usb port it boots normally to windows but if i removed the flash drive not inserted to usb ports and turn on the laptop,it directly go to bios setup.I already check the settings in the bios on boot device priority and hardrive first on the first boot.anyone can help me to solve this problem please
asus x452c weird problem
by lazaro.089Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
CPU: Core i9-12900H
Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and... -
by AtelierRepaHello,
I have a problem with the bios, let me explain.
With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....-
Channel: BIOS Requests ONLY!
by lukkihapsiAsus Vivobook X515JA Laptop
Issue :
Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
Tried :
Cleaned inside for dust, applied fresh thermal paste. No Change!
Removed keyboard, Trackpad, fingerprint sensor. No Change!
Removed Internal SSD. No Change!
Updated BIOS to latest version. No Change!
Removed battery and pressing power button for 1 minute. No Change!
Weird Part :
Upon turning laptop ON, screen lights up - stays black,
I... -
by DobrowolHi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?04-28-2025, 04:30 PM
by RotVikHello, I need a little help
I got an ASUS PRIME B550M-A AC Motherboard, bad BIOS, it wont display or boot, unless I did CMOS Restart first, after that It will boot but if I modified the configuration of the bios and saved it ,again no image
I got the BIOS .CAP file from ASUS official support, used a tool called ASUS CAP to BIN, and programmed it to the IC, soldered to the board and got it to boot correctly, all the way to Windows, but now the CPU fan stays at full speed all the time and if I try to power it off with power button it will restart instead, and there are...-
- Loading...
