Hello if i use Windows PC where is possible to download ISO of Snow Leopard for o reinstall OS on machine?
Info iMac late 2009
Tags: None
Re: Info iMac late 2009
use google man
Code:https://www.google.ba/search?client=firefox-b-ab&dcr=0&q=mac+os+x+Snow+Leopard+torrent&spell=1&sa=X&ved=0ahUKEwiz44qYkY7YAhUD6aQKHckFCs4QBQglKAA&biw=1280&bih=891
good luckIm Back... sort of... -
Thank you Ala you are real resourceComment
if you like to come over i have every version form 10.7.0 to 10.12.2 with combo updates
i can copy it to you
other than that the best way is to get a working mac, start downloading and trying one by one and test if it worksIm Back... sort of...Comment
by jasobrinoHello everyone,
Some time ago I acquired an imac computer model A1311 that does not boot (motherboard ref. 820-2494-A).
The power supply is working properly (I have two), it delivers the 12V on pin 4 of the power connector (PP12V_S5).
As I have the schematic diagram and the boardview, I have made a series of measurements, obtaining the following results:
PP12V_S5 -> 12V
3V3REG_VCC -> 3.12V (something low?)
PP5V_S5_LDO -> 0.02V
3V3REG_VCC -> 0.0066V
I have also measured the resistance to ground on the coils, and I can't find... -
Apple iMac A1418 LATE 2015 820-00034 051-00081 Boardview...
Channel: Schematics and Boardviews
10-22-2024, 03:39 AM -
by webhxHello
I received 27" iMac, Late 2015 model that's broken. I don't know what exactly happened but it appears to be unopened and there are no marks indicating prior repair attempts.
Initially it didn't display anything on the screen and backlight didn't work. Only 2 diagnostic LEDs would light up and 3rd was very faint. I opened it and found F4400 fuse near eDP connector to be blown. Replaced it with a suitable part and backlight came back to life. Unfortunately it still doesn't display anything on the screen. Now I get 4 green diagnostic LEDs.
I can hear the chime... -
by guzqHi Guys,
I need your help to check my BIOS, it stuck on 3/4 progress apple logo loading bar.
Thanks...-
03-15-2022, 12:49 PM -
by ex250Hello guys, I have this one with a non-starting failure, on board diagnostic led 1 lights ok, tested other know working power supply to discard, same behavior.
The board is the 820-2494A
the S5 lines read:
PP1V1_S5_REG -> 1.11V
PP3V3_S5_REG -> 3.37V
PP5V_S5_LDO -> 4.98V
PP12V_S5 -> 12.01V
Seems all ok
This ones not, too high readings, maybe the same culprit:
PGOOD_1V1_S5 -> 3.37V (should be 1.1V?)
5VREG_EN -> 3.37 (should be 5V?)
I was thinking... - Loading...
