HP 14 Power problem
  • joelz
    • Aug 2013
    • 18
    • jakarta
    HP 14 Power problem
    Hi guys, I have problem power on for hp 14 with intel celeron prosie. when the button power get press the light on keyboard only light up in second end goes off. but the led charger indicator is always on. i have check it on mobo for power 3.3v end 5v not on but when i press the button power the voltage for 3.3v end 5v is on for a second end goes off. but i have voltage on pin 5 on one of bios ic.
    my quetion is... should be have voltage 3.3v end 5v before i press power button or not ? thanks..
  • Elsid79
    • Aug 2015
    • 47
    • Ukraine
    Re: HP 14 Power problem
    what kind of platform(MB) is hp 14?
    • joelz
      • Aug 2013
      • 18
      • jakarta
      Board Model is OSAMU2_BT_HPC MV_MB_V1
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • EazyBone
        LG OLED55C9PUA power problem
        by EazyBone
        Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
        Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
        I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
        The power supply to t con is different story.
        This...
        06-23-2023, 07:43 AM
      • Dr.d
        Help please..Lenovo ideapad 5 14itl05 power and charging problem
        by Dr.d
        I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
        Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
        04-05-2024, 11:48 AM
        03-31-2024, 02:12 PM
      • Chris_p
        Msi mag b660 wifi ddr4 no power problem
        by Chris_p
        Hello I have a msi mag b660 wifi ddr4 board that I’m unable to get to power on. Ive bought it off a auction site so no history on the board and no warranty, got it super cheap, trying to make a budget build and it backfired.
        I’ve tried to jump the power pins and also hook up the power switch from my case and no signs of life.
        i have jump the power supply while not connected to the board to confirm power supply is good and it is.
        I have installed the cpu, ram and graphics card than removed them one by one to rule out them as a fault.
        im...
        09-21-2024, 01:31 PM
