HP 2530p not charging (LA-4021P)
  • djdblaster
    • Sep 2017
    • 16
    I have this laptop, worked all good and then one day, plugged it off, cut the power cable and since then it doesn't want to charge. However, the battery was charged all the way up so I could use the laptop for few hours. The battery still has some juice in it I believe.
    But, like the title says, it doesn't charge the battery.
    There is 19.36V on DC Jack and also at the first PQ300 mosfet.
    BQ24740 requires 19.36V on pin 28, right? I have 0.387V. Signal comes from CHG_B+ which is also shown on the line where the PQ300 mosfet is along with another PQ301 mosfet. I've made a jumper from PQ300 pin 4 to PQ301 pin 1 and laptop starts. Removed it after. I've also made a jumper from PQ300 pin 4 to ground, laptop starts. Removed it after. That was just testing.
    Replaced PQ300, no luck.
    Right now I'm confused where should I look at? My instinct tells me that battery charging IC is dead?
    I have schematics if anyone is interested to take a look.
  • Udemzy
    • May 2017
    • 164
    • Guatemala
    Re: HP 2530p not charging (LA-4021P)
    Read the battery positive and negative pin with a multimeter in continuity, interchange it and see if both side read continuety.
    If it does, then there is a short circuit at the ba3 side if not, you can troubleshoot with the laptop schematic diagram.
    • henro24
      • Mar 2018
      • Nigeria
      Hello i have power issue with my elitebook 2530p as well. Formally it was blinking light when i try to power it but later there is no sign of any power at all whether with battery or charger. Please i really need help on the ic that could be responsible. Thanks
      • costivl
        Lenovo Y50-70 PQ301 overheating
        by costivl
        First of all please excuse my bad english as it is not my native language.
        Two days ago when i was working on my laptop i felt that the left side of the keyboard is very hot and after 1-2 minutes i felt a smell of burnt plastic, i turned off the laptop, then i opened it inside and i found out that the power jack that connects to the motherboard was melting, i ordered the cord and replaced it, i was trying to find out the cause for that overheating and i just learned that the mosfet PQ301 is causing the overheating. Just to mention my laptop works perfect on battery...
        04-14-2020, 09:58 AM
        HP EliteBook 2530P LA-4021P JAT00 Notebook Schematic
        HP EliteBook 2530P LA-4021P JAT00 Notebook Schematic...
        10-03-2024, 06:35 AM
      • iblackford
        ASUS ROG MAXIMUS PQ301 gets hot
        by iblackford
        I have two slightly different (but I'm sure similar...) ASUS ROG motherboards that have essentially the same fault. They are the ASUS MAXIMUS VI GENE and the ASUS MAXIMUS VIII HERO. Both have excessive loading on the +3VSB rail, which makes PQ301 get very hot. I did some searching through the forums, and it looks like someone had another ASUS motherboard with the same fault, but there was no follow-up on what eventually fixed it. I feel like it should be a common issue, but I don't know. Does anyone have any insight on what components are most likely at fault? Does anyone...
        01-04-2024, 10:45 PM
      • ziko07
        hp elitebook 2530p strange problem
        by ziko07
        Hi, I have this laptop , battery charge ok, also when powered ON and insert charger battery charge ok, but problem is IF charger is inserted and no matter if removed after that when switch off laptop or going hibernate when lid closed, in that case cannot start again when pressing power button, unless I reinsert battery.
        When operate on battery only no problem at all.
        Also, if remove battery and use charger only no way to start laptop ( I have second same model and it works on charger only fine).
        There is sensor touch button (see image) when pressed on good laptop ,laptop...
        05-20-2024, 11:45 PM
      • loran
        Dell AW 13 R3 with cpu failure blink code
        by loran
        Hi all!
        I was working on my emails and suddenly the system crashed in an instant. No life sign at all. Not even power leds.
        On the mainboard a mosfet was burnt (see picture) so I decided to replace the two mosfets with new AON7422G.
        The part numbers are PQ300 and PQ301 (see schematics).
        After the replacement the laptop shows 2 red and 1 blue blink code.
        That's a cpu failure code according to Dell.
        Does that mean the repair went well?
        I read that a corrupt bios could be the cause for cpu failure code so I created a bios dump...
        11-14-2020, 05:31 AM
