asus g750j 19v on bat_con
  • myth77
    • Feb 2017
    • 380
    • Croatia
    history:
    1. was shorting charger, find out that capacitor PCE6000-poscap 15uf/25v wad dead, replaced it.
    2. After that the laptop starts, i have a screen but its not charging battery. I find short relating ground on battery net, replaced mosfet pq8805-nmosfet ntmfs.... now there is no short on battery net...
    3. today i tried to assamble laptop, and when i tried to check voltage relating ground on battery connector, just to be sure, i have 19v on bat_con net relating ground?! i am not sure is this ok? should be lower or? on other three pins on connector i have 3.2V.
    Boardview attached.
    Last edited by SMDFlea; 12-27-2020, 07:27 AM. Reason: Removed dead image hosting links
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: asus g750j 19v on bat_con
    Using mobile now so can't check boardview
    If 19v on bat connector
    It means 19v is reaching via last mosfet near connector
    Blocking mosfet which blocks 19v to reach battery connector is shorted or not working
    Remove adapter and check voltage
    3.2 volt on 3 pins of connector is ok
