Acer 5742G Black screen
  • John_F_L
    • Mar 2017
    • 72
    • Greece
    I have an Acer Aspire 5742G (LA-5891P motherboard), which about two months ago I reballedthe graphics card and came back with a problem that does not show on the screen (then it was showing lines).
    Just to be sure, I changed the chip with a new one.
    Before changing it, the laptop did not even show on an external screen, now it does, but nothing on the laptops, not even the inverter lights up.
    I've already tried another screen but nothing changed. I don't have a LCD cable to test test, I have to order it. Is it possible to be the cable, or look back on the BGA?
    What has surprised me of course is that at pin 5,6 of the lcd connector where is + LCDVDD I measure 0V, while on + LCDVDD_R (pin 4) I have 3.3V and in TXOUT and TXCLK 1.2V it drops back to 0 and goes up again the 1.2V.
  • mielta
    • Apr 2015
    • 368
    Re: Acer 5742G Black screen
    Hi
    Please mesure on R279
    and mesure on PIn123 at LCD Connector
    • John_F_L
      • Mar 2017
      • 72
      • Greece
      R279 is 0V but R279 is for RAM. If you meant R729 (just under the connector) it is not there, but when I put it on (0ohm), nothing changed.
      pin 1,2,3 is 19,4V.
      • mielta
        • Apr 2015
        • 368
        Pin 4,5,6 there must be 3,3V at least
        • John_F_L
          • Mar 2017
          • 72
          • Greece
          pin 4 is 3,3V.
          pin 5,6 0.
          source on both q28 and q30 is 0V, gate 3,3V and of course drain is 0V (I think there should be something on source)
          when I press the power button source on q30 goes to 3.3V but 0 on the drain again.
          • John_F_L
            • Mar 2017
            • 72
            • Greece
            just to mention, when I put the 0ohm resistor r729 the voltage on pin 4 becomes 0V instead of 3.3V that is right now.
            • mielta
              • Apr 2015
              • 368
              Check ENVDD on Q31 whwn power on
              • John_F_L
                • Mar 2017
                • 72
                • Greece
                i measured that sometime ago and it was 0,3V.
                right now it is 0V.
                • mielta
                  • Apr 2015
                  • 368
                  Hi
                  I Think there is anything whis the grafikchip Signal comes from there
                  when it is new than reball it again
                  • John_F_L
                    • Mar 2017
                    • 72
                    • Greece
                    I'll reball tomorrow, and tell you what will happen.
                    • John_F_L
                      • Mar 2017
                      • 72
                      • Greece
                      I reballed the chip, the same happens. Voltage on Q31 ENVDD goes up to 56mv.
                      • mielta
                        • Apr 2015
                        • 368
                        Hi
                        The gate from Q30 must be lower than 3V from the source so that the voltage can be go
                        to the Drain
                        if you have an external Powersupply i Woud do 3v at the Drain of Q30 when laptop is powered on
                        And see what is happend
                        • John_F_L
                          • Mar 2017
                          • 72
                          • Greece
                          I tried that and the only change is that the backlight just lights up. But still no image on the screen. On the external display the image is correct, no artifacts.
                          • mielta
                            • Apr 2015
                            • 368
                            That shows me that everything is wrong with PCH or Garfikchip
                            pch_envdd page16
                            en_vdd page22
