KB9012 and KB9022
    KB9012 and KB9022
    Is kb9022 interchangeable with kb9012?
    Pin detail is same btw but when I put kb9012 on kb9022 board rt809f doesn't recognise it.
    Any help will be appreciated.
    Re: KB9012 and KB9022
    Did you program the kb9012 ?
      No, I mean. I have program kb9012 on many Dell and Acer machines successfully but never able to program kb9022.
        does not work 9012 instead of 9022
          still struggling on KB9022, why is there error while reprogramming KB9022 with RT809f. Any idea?
            No idea as i use SVOD and it works perfectly for 9022
              i have two of this vaw01 la-9101p rev 1.0 for repair bot are exactly the same but one is KB9022 and the other is KB9012 i need to be sure about if will work one instead other.
              as a plus both mobo have the kbc burnt
              just in case the schematic for this model says the kbc is KB9012
                LA-9101P/9104P uses ENE9012. KB9022 wont work. It may be some earlier technician has replaced the kbc.
                  KB9022 programs just fine on my RT809H. Are you programming in circuit or using the small adapter board?
                    I also need kb9022q d tatasheet with with complete insctruction
