Sony VAIO SVF1512C6EW Rev.F suddenly doesn't show anything ?
  • Acnologia
    • 421
    • Poland
    Hello to all,
    Today i had a computer from a friend of mine to change thermal paste etc. to clean the inside of the laptop,it's an operation that i have long done so many times in so many laptops but today my luck was , hiding in another place.
    The laptop was working great, all good .
    I changed the thermal paste,cleaned the vents all great (Thermal Paste: Arctic Silver 5) .
    Turned on the laptop logged in the Windows, backup everything ,and then restarted the computer logged into BIOS settings to change the BIOS from UEFI to Legacy and the Secure BOOT -> Disabled,all that for the laptop to understand that i have a "USB Stick" ready to go for the Windows 10, restarted again logged in the computer, all was good .
    I restarted then , and from then the laptop turns on but doesn't show anything!
    Stuff that i have already made.
    1. Cleared CMOS
    2. Changed Battery in case of drop Volt
    3. Checked 4 different kind of RAM
    4. Changed the charger
    5. Double - Triple check all the cables
    6. Remove everything and try to turn on the laptop without anything on it just a barebone of motherboard with only CPU + RAM + power button + DC port connected nothing else.
    7. The CPU is heating UP a lot , not any other part of the laptop not vrams not capacitors all clear and cold ,the CPU i measured it that it heats up ,up to 60 celsius inside 30 sec.without posting anything (changed again thermal paste to be sure)
    Again nothing.
    Can all this result that the CPU is DEAD,or something else has been blown ?
    Now,before the last restart as i was typing into the computer and until restart, i moved the USB from 3.0 to 2.0 , to check if everything Okay ,that's the last thing that i did before restarting the computer...
    I tried to explain everything.
  • nixi22
    • May 2016
    • 44
    • Croatia
    Re: Sony VAIO SVF1512C6EW Rev.F suddenly doesn't show anything ?
    Sound like corrupted bios, try flash it.
    • dskall
      • Oct 2016
      • 2905
      • usa
      I would check around cpu pins, caps etc. with magnifying glass for damage shorted pins. Getting good contact with heatsink?
      • Acnologia
        • 421
        • Poland
        Can you believe that i have , searched the ENTIRE motherboard and can't find the BIOS Chip ?
        Yes,already done that double-triple check with magnifying machine not just glass.
        • String2016
          • Nov 2015
          • 2229
          • philippines
          post a clear image both sides of the motherboard
          • Acnologia
            • 421
            • Poland
            Here are all the pics that i took,sorry but i don't have a DSLR or something.
            https://s29.postimg.org/xeuwmeyav/image.jpg
            https://s29.postimg.org/f4e6yorhj/image.jpg
            https://s29.postimg.org/rryjoxvs7/image.jpg
            https://s29.postimg.org/4gafzuhif/image.jpg
            https://s29.postimg.org/tl1gd9gyv/image.jpg
            https://s29.postimg.org/pfqjrcj6v/image.jpg
            https://s29.postimg.org/960dog8iv/image.jpg
            And to catch you up the only chip that i can find that is inside the schematic database etc. is the one that says ""cFeon Q64-104HIP Q24L04A 1231LDA""
            • Acnologia
              • 421
              • Poland
              Here is my dumb file that i have read from my programmer.
              • Acnologia
                • 421
                • Poland
                Does anyone have the file , or can help out fixing this one ?
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  I Have this feeling the CPU is fried , although sometimes thermal protection sensors onboard would prevent it from starting .
                  I bet this Sony was suffering heating problems and random restarting , or instant shut downs . Maybe that's why you were changing paste and pads .
                  One interesting symptom in dying processors i've always noticed , is , when and if the system start again , prior to its total failure , the system wouldn't notice what's happening , meaning , he won't go in safe mode or any windows similar warnings and precautions . The system will just boot on normally as if nothing happened ...
                  I hope i'm wrong , but only last week , i changed a Core2 Duo cpu on a Sony vaio .
                  • Acnologia
                    • 421
                    • Poland
                    No it wasn't suffering.But one time per year i clean and install new thermal paste.I want my systems to be in Great shape.
                    I am just going to buy a new CPU ,to check it up but 1st i want to be sure about the BIOS
                    • jiroy
                      • Jun 2016
                      • 2416
                      • Lebanon
                      Maybe one of the Bios Gurus around will help you then . Vaio ones were always a rarity . Doing searches about your model number shows almost nothing on the net .
                      Good luck .
                      • age80
                        • Jun 2013
                        • 55
                        • Greece
                        Your Motherboard is this da0hk5mb6f0
                        so go there--->>>
                        https://www.badcaps.net/forum/showthread.php?t=41215
                        • caspian
                          • Oct 2015
                          • 1589
                          • Laptop
                          Does the fan spin at maximum speed with CPU plugged in?
                          Does the PCH get warm? or it is completely cold?
                          Does it show any blink/beep code if you turn the laptop on without CPU?
                          • Acnologia
                            • 421
                            • Poland
                            Good luck .
                            so go there--->>>
                            Thank you all for the information and the answers but i fixed it with the most strange way ever.
                            I installed the latest BIOS , update via programmer , and with a little bit mod on the BIOS itself and tried to turn it on ,nothing was shown...
                            Then i re-installed the DUMB that i had read from the laptop when i was trying to check about the BIOS ,and...
                            The laptop works.I just re-flashed the BIOS (Dumb) from it's self.
                            Strange.....
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              And now cpu does not get hot?
                              • jiroy
                                • Jun 2016
                                • 2416
                                • Lebanon
                                Strange.....
                                It's kinda not strange . When a CPU is prevented from starting by the Bios thermal sensors system , you'll have to convince that Bios that something has changed ... Resetting Bios , new programming , etc , etc .. could do the trick . Glad your troubles is over anyway ..
                                • caspian
                                  • Oct 2015
                                  • 1589
                                  • Laptop
                                  glad it worked.
                                  what was the fan's behavior before and after the bios programming?
                                  • Acnologia
                                    • 421
                                    • Poland
                                    No , in stress after 2 hours it is stuck on the 75~78 , doesn't hit 80.
                                    Yes, but it was done already one time,that's the strange thing. Now that i got back the original dumb everything was just fine.
                                    glad it worked.
                                    The same .
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      I have read about things like that happening often with TVs. Many times just dumping the flash memory and rewriting the same contents will make it start.
                                      My guess is that the flash itself is being damaged and getting unstable, and a rewrite refreshes the cells so to speak.
                                      Keep the dump saved, if it happens again, program a new BIOS chip and solder it in. I've replaced quite a few flaky ones in the past 2 years.
                                      A working TV? How boring!
                                      • Acnologia
                                        • 421
                                        • Poland
                                        me too ,but never had something like that.Most of the times i was reading , what is was needed to be fixed in a dumb,and then flashing into a new chip could make it work. But this occured for the first time..
                                        In the end ?
                                        For everything exists the "1st time"...
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                          This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                                          Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                                          This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
