Hp 15n da0u81mb6c0 laptop no display
  • sureshbobby
    • Mar 2015
    • 137
    • India
    Dear Friends
    am having hp 15N with DA0U81MB6C0 motherboard which is not working.
    Laptop is powering on and fans are running. but no display,
    please tell me the voltage points to check and troubleshoot
    Thank you
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Re: Hp 15n da0u81mb6c0 laptop no display
    Check voltages on Coils ( Gray square components ) around CPU.
    • sureshbobby
      • Mar 2015
      • 137
      • India
      Yes
      PL13-1.1v
      PL14- No voltage
      • raajkumar
        • Mar 2015
        • 354
        • Srilanka
        I suspect PU4 or PU3 or both. So check voltages according with Schematic.
        • Rashid36
          • Aug 2014
          • 59
          • Saudi Arabia
          Bro try bios only........
          • sureshbobby
            • Mar 2015
            • 137
            • India
            Hi bro
            Am using MINIPRO TL866a programmer, Unable to flash the bios or read the bios. is it compatiable or i have to use another programmer.
            If yes please suggest me a good programmer.
            • sureshbobby
              • Mar 2015
              • 137
              • India
              Dear Raajkumar,
              I will check the both PU3 & PU4 and let you know
              • Rashid36
                • Aug 2014
                • 59
                • Saudi Arabia
                Originally posted by sureshbobby
                Hi bro
                Bro i'm using EZP2010
                • sureshbobby
                  • Mar 2015
                  • 137
                  • India
                  Hi Bro My motherboard model is DA0U81MB6C0
                  QUANTA U81
                  • udai
                    • Oct 2014
                    • 6
                    • india
                    flash bios .check blinking in k/b
                    • sureshbobby
                      • Mar 2015
                      • 137
                      • India
                      Hi Udai,
                      Thank you. but i was unable to flash bios with my Bios programmer TL866A
                      will you guide me
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        check whether its a 1.8v chip. If so, you will require 1.8v adapter
                        • sureshbobby
                          • Mar 2015
                          • 137
                          • India
                          I cannot program both main and ec bios, Please suggest me
                          • Shamsi
                            • Oct 2015
                            • 31
                            • india
                            Same problem to me also.Both bios flashed.but no vcore coming.1 caps lock blinking
                            • piernov
                              • Jan 2016
                              • 4435
                              • France
                              Missing S0 rail and/or ALL_SYS_PWRGD maybe.
                              • ravi_1617
                                YY Solutions
                                • Jan 2012
                                • 343
                                • India
                                Hi, Same board,DA0U81MB6C0 with graphic -no display.
                                Found U24 Audio and U9 Lan chip heating removed both , but still no display.
                                U23 Intel seems heating bit more along with heat-sink around 50-55 max. Should i replace intel.
                                power at coils seems normal.PL13 1.1volt .no 0 volt at PL14.
                                Looking for bios with graphics. felt webcam also heating.
                                Please Guide me.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Very likely a shorted pch on usb section. check reistance on D+/D- on usb port.
                                  • ravi_1617
                                    YY Solutions
                                    • Jan 2012
                                    • 343
                                    • India
                                    Thanks i will check and update
                                    • ravi_1617
                                      YY Solutions
                                      • Jan 2012
                                      • 343
                                      • India
                                      Cheaked D+/D- showing 5.5 to 5.9 Meg-ohms .
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        Audio/Lan/Webcam -all controlled by PCH. So i doubt some damage to PCH itself. USB resistance is fine though. PIN3 of PU4?? Disconnect webcam and try to boot. Is there display?
