dis to uma conversion
    can a hp probook 6930p convert form dis to uma?
    Re: dis to uma conversion
    anyone please i just want to know if this model of hp can be converted to uma?
      please upload the schematics to check.
        There are two versions of this motherboard , WISTRON KARIA DIScret & WISTRON KARIA UMA .
        IF your motherboard is P 40/45 north bridge, then you need to change it to G45 ...
        Find the scheme WISTRON KARIA DISCRETE and in the search for PDF VIEWER write the UMA
        The BIOS also needs to be changed
          Look at the pictures of difference
          I have both schemes, if required, I can upload here
            board is in winston karia discret can you please upload schematics and show tutorial to converts this please thanks in advance
              What is the reason to change dis to uma on so old laptop? As elekto-nik wrote, you need to change NB and a lot of other parts to do it working.
              It is much easier fix problem on gpu, if you have some.
                thanks for the response because gpu have problem if i reflow or reballed it wont last
                  WHICH NORTHERN BRIDGE IS WORTH?
                  Wistron_Karia_Dis
                  Wistron_Karia_UMA
