HP ProBook 4535s Plugged in charging but not charging
  • Sojke
    • Apr 2017
    • 131
    • Serbia
    I have an HP ProBook 4535s that sees the battery, says it is plugged in and charging but it is not charging. Not even when the laptop is off.
    I have tried 4 different batteries, two used and two new which all charge in an dead laptop except the original one that is not detected.
    I have replaced the charge controller BQ24726 (U1015) and two transistors FDMC8884 (Q1045 and Q1046) yet same thing occurs.
    No shorts, cap between SRN and SRP is good (C1270), at least I believe it is since it is not marked on the board and I believe it is located above U1015.
    I have no idea what to do.
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: HP ProBook 4535s Plugged in charging but not charging
    Check:
    vcc on R1240 is ok ?
    Q1048 and Q1047
    on chip bq24726 pin 3-4-5-6-
    • petehall347
      • Jan 2015
      • 4426
      how can it be charging and not charging at the same time ?
      • Sojke
        • Apr 2017
        • 131
        • Serbia
        Jasko was spot on, Q1047 was bad and always on Source to Drain which caused the battery charger to always return into laptop circuitry and not the battery via +VADPBL always existing and Q1049 always connecting the battery lane with the laptop power lane.
        • Thomasraud
          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
          by Thomasraud
          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
          QUOTED
          -It works on charger (without battery connected-only charger)
          -It works on battery (without charger connected-only battery)
          -& it also works when plugged in battery & charger, but it's not charging the battery
          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
          and..
          QUOTE
          The IC cannot maintain the input current level
          06-28-2022, 06:47 PM
        • Shinju
          Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
          by Shinju
          Hey All!
          Long time forum member here with a problematic laptop issue!
          I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
          The laptop would not power on with the new battery installed without the power supply being plugged in.
          When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
          TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
          10-20-2021, 04:58 PM
        • Julian Bailey
          HP ProBook 445 G8 Battery not charging
          by Julian Bailey
          Hi all
          We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
          The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
          I have gone around the board with a MM and cant find anything
          Windows shows the battery fine,...
          10-11-2024, 10:34 AM
          HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
          This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
          09-07-2024, 05:50 AM
