Acer e15 wont start
  • gbaicu51
    • Feb 2015
    • 29
    Acer e15 wont start
    I have an acer e15 wont start. I find 8pin mosfet pq304 as bad now start all components except display - just an very fast flash(backlight) permanently. Also on usb i have 5v but connecting an usb (with led) not seem to work.
    Any ideea please?
  • LP_tekh
    • Oct 2015
    • 95
    • Laos
    Re: Acer e15 wont start
    Try to flash the bios my friend, may that's the problem.
    • gbaicu51
      • Feb 2015
      • 29
      thanks for reply . i have an usb with led indicator and seem to dont work . no blinking lights on the stick . but when i check with multimeter i have 5v. Also at pin 1 on display conector , i have 19v wich i dont know if is correct as i cannot find any schematic mobo is :z5wah la-b161p rev 1.0
      ps :
      i flash on the past one acer laptop with usb (black screen). i will try to add some photos with mosfet replaced
      • ipn00tic
        Acer vx5-591G I removed Mosfet and it works without it?! could it cause problem?
        by ipn00tic
        Hello everybody,
        I'm learning alone at home (with you) of course.
        I have an Acer VX5-591G laptop that was given to me as scrap where I was training and diagnosing.
        The Laptop turns on and starts to boot for a few seconds but before displaying any image it short circuits the main 19V power supply and turns off.
        I managed to "repair" the laptop and it turns on and everything works, I even did game tests for the CPU and GPU and everything works but what I did was remove a Mosfet (PQ807) from the VCC_GT power supply.
        The VCC_GT power...
        03-01-2024, 05:32 AM
      • jermac0711
        ACER PEW71 LA-5894P CPU_B+ MOSFET NEED HEPL
        by jermac0711
        Brand : Acer
        MOBO: PEW71 LA-5894P
        Issue: initially no power. PQ73 mosfet is busted. (AO4466) . Unit has power now but PQ87 is heating up too much (observerd under thermal camera) causing to shut down the system. I tried to remove the removable CPU and the mosfet temperature went normal. I have a replacement CPU from same model but everytime there's a CPU, mosfet PQ87 temperature is rising rapidly.
        I hope you guys can shed some light. Thank you so much in advance.
        12-17-2024, 08:25 PM
        09-06-2024, 05:27 AM
      • Kshi
        Acer a515-52g no power 19v not passing through first mosfet
        by Kshi
        I purchased this laptop from fb marketplace
        and the previous tech jumped 1st mosfet. maybe it got fix, then time comes by jumpering fried the charging ic?
        tried to change mosfet but it does nothing 19v is not passing through 1st mosfet
        tried to jumper again, I got 5vlp and 3vlp but 5valw and 3valw is missing
        I suspect that the charging ic is bad? If so how do i test if it is bad.
        Cant see any short or corrosions on board
        schematic and brd view attached below
        07-25-2025, 01:13 AM
      • vexarvf1s
        Acer: No power after first MOSFET no short? Looking for guidance.
        by vexarvf1s
        Looking for guidance in tracking down missing main power rail.
        I have an Acer that I am working on. It runs on the battery, but does not charge. I changed the power adapter and same thing battey not charging, and continues to discharge. So I opened the computer and started looking for the problem to fix.
        First thing I checked is if the power form the charger is getting to the mainboard. I found that 19V is going all the way to the first MOSFET. So DC jack is fine. However I do not have power past the first MOSFET.
        So checked for voltage on the gate of the first MOSFET and...
        05-13-2023, 07:55 AM
