Dell laptop with power problem
  • emmanuelbill1988
    • Mar 2017
    • 100
    • ghana
    please I really need urgent help,I have this dell laptop board with power problem,when i put the charger in the power jack the charger light goes off,i checked if there is a burst in the caps but I couldn't see any and i decided to change this Ic's
    PQ0100
    PQ101
    PQ110
    PQ108
    PQ102
    PQ704
    PQ702
    PQ703
    PQ300
    PQ204
    PQ205
    PQ203
    PQ500
    PQ501
    PQ701
    PQ700
    after changing them still the problem is not solved, can someone please help me with what i should do next,the board number is LA-9104P Rev:1.0(A00)tnx in advance
  • emmanuelbill1988
    • Mar 2017
    • 100
    • ghana
    Re: Dell laptop with power problem
    And i put my multimeter on buzzer and check the positive lines it beep without the charger plugged inn which means there is a spoilt component but I can't find it,please someone should help me out
    • polytek
      • Dec 2013
      • 496
      • TUNISIA
      please post your mobo code, sorry i see it now
      • emmanuelbill1988
        • Mar 2017
        • 100
        • ghana
        mobo number is LA-9104P Rev:1.0(A00),please need help seriously
        • piernov
          • Jan 2016
          • 4439
          • France
          Are you serious? We already answered that on your other thread and you open a new one without even bothering answering us?
          https://www.badcaps.net/forum/showthread.php?t=62131
          And you swap component randomly without even trying to think for yourself…
          We still need to know what resistance do you get.
          Anyway, when you've got a short on some line, one method to find the faulty component is to put some voltage on it using a lab power supply. Start with 1V and check if anything gets hot, especially CPU, GPU and PCH and check the current drawn. We will go from there…
          • emmanuelbill1988
            • Mar 2017
            • 100
            • ghana
            all the components on the board reads like a fuse or PL so I don't know which one maybe causing the GND problem
            • polytek
              • Dec 2013
              • 496
              • TUNISIA
              http://www.zupimages.net/viewer.php?id=17/20/xape.jpg
              • emmanuelbill1988
                • Mar 2017
                • 100
                • ghana
                polytek I have removed the solder PJ and checked caps but still
                • raajkumar
                  • Mar 2015
                  • 354
                  • Srilanka
                  Same problem happen to me. I inject 1v power on 3V line and i found KB chip came hot. I replaced it the problem solved. You try to inject like that first you should remove Supply coils.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Open all the jumpers and see which side of jumper is shorted and then trace that line to find faulty componenet. No need to change all the componenets randomly-the mobo may get damaged rather.
                    • emmanuelbill1988
                      • Mar 2017
                      • 100
                      • ghana
                      tnx very much guys,the board is working perfectly now,i opened jumper PJP500 but still there was a short on the mono and all I did was to give the board a 20v charger,after few seconds I release the two caps closer to PJP500 one was smoking,so I changed it and now board is working,I have really learnt a lot in this forum,Bless you all and especially Polytek for helping
