IdeaPad s500 Touch sorted
  • John_F_L
    • Mar 2017
    • 72
    • Greece
    I have an Ideapad S500 touch which is not powering on.
    In the beginning I thought there was a problem with the TPS51225 controller which was very hot. I change it and the same was happening. Then I change the IT8528E IO Chip but again the same happens.
    I then found out that 3 coils and a lot of capacitors are shorted to ground. Also all the capacitors on the CPU BGA are shorted.
    Is there any way to find out where the short starts?
    I don't have the schematic to see how the circuit goes.
    The motherboard doesn't write any model except from Chip Main Board V2.1
  • khaahk
    • Dec 2013
    • 755
    • Estonia
    Re: IdeaPad s500 Touch sorted
    Find a datasheet for TPS51225, there are LDO outputs and SMPS outputs. Measure resistance of both - which one is shorted?
    Use a lab power supply to find short on the rail. The method is described in this forum or google for it.
    CPU itself is low resistance - so 3-5 ohms is not a short.
    • John_F_L
      • Mar 2017
      • 72
      • Greece
      None of the outputs of the TPS51225 are shorted.
      I forgot to mention that 3,3V and 5V are present on the system.
      • khaahk
        • Dec 2013
        • 755
        • Estonia
        So vreg3 and vreg5 are 3.3 and 5V respectively?
        SW1 and SW2 are also outputting?
        Just the tps is getting hot?
        What resistance do they have?
        How much current does the mainboard use when plugged in?
        What resistance do you have on the cpu caps?
        • John_F_L
          • Mar 2017
          • 72
          • Greece
          Re: IdeaPad s500 Touch shorted
          SW1 = 3.6 Kohm 5mV
          SW2 = 4.1 Kohm 20mV
          VREG 3 = 0.745 ohm 3.3V
          VREG 5 = 3.4 Kohm 5V
          The lab power supply won't go over 0,05A.
          Almost the same measurements and with a new TPS
          Caps on CPU max resistance was 2.7 ohm
          edit:
          After installing again the TPS (to be sure that it was OK on the board) I have 3.3V on SW1 and 5V on SW2. And also the resistance of the VREG5 went on 12 Kohm. All the others are the same.
          • khaahk
            • Dec 2013
            • 755
            • Estonia
            VREG 3 resistance is too low. That is why the chip is overheating.
            Inject voltage from lab supply and see who else is heating up. (LAN maybe or something else)
            • John_F_L
              • Mar 2017
              • 72
              • Greece
              I don't see anything else heating up.
              But my problem still is not why the TPS is heating but why so many components of the machine are shorted to ground. If the TPS is out of the circuit, it is still shorting so that is not my cause.
              • khaahk
                • Dec 2013
                • 755
                • Estonia
                0.7 ohms on VREG3 rail is a problem.
                low resistance (which might not be a short) on random places on board - hard to comment without schematic available.
                • John_F_L
                  • Mar 2017
                  • 72
                  • Greece
                  Propably the rail as you told.
                  I tried also to remove some big components like inductors, the big caps, and some mosfets but nothing changed.
                  The last thing I tried was with freeze spray the first time and alcohol the second to see where it might get hot, but the only thing that was heating up fast was the TPS.
                  • khaahk
                    • Dec 2013
                    • 755
                    • Estonia
                    If i had the mainboard at hand i would:
                    remove tps
                    solder a lead to VREG3
                    Put 3.3V to it from LAB supply (1A at first, if needed up to 3A or more)
                    something must become hot, if big chip (like PCH) then might only be slightly warm
                    • John_F_L
                      • Mar 2017
                      • 72
                      • Greece
                      I tried what you said but the Amper won't go over 0,03A on my Power Supply, no matter how much I turn the dial.
                      I tested that the lead won't touch anything else nearby.
                      So definetely something wrong with the rail.
                        Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                        This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 05:20 AM
                        Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                        This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                        This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                        Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook 3 Specification for Upgrade or Repair
                        This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 05:00 AM
                        Lenovo IdeaPad IdeaPad 3 15IML05 Notebook 3 Specification for Upgrade or Repair
                        This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
