lenovo G585 power issue
  • vickey_vip
    • Mar 2016
    • 136
    • India
    i have a power problem laptop which model is lenovo g585 and mobo part no is QAWGE LA-8681P REV 1.0.
    i check it and found no 3.3 voltage anywhere i check schematic of this motherboard but i cant fine which and where is power ic who generate 3.3 volt please help me
    i am attaching schematic which i found
  • shuc
    • Jun 2012
    • 30
    Re: lenovo G585 power issue
    If I'm not wrong at page 38, PU301, (BQ24727RGRR)
    • vickey_vip
      • Mar 2016
      • 136
      • India
      you are right but in this location my motherboard have bq727 ic which is for battery charging
      • shuc
        • Jun 2012
        • 30
        it's the same IC
        • shuc
          • Jun 2012
          • 30
          check for datasheet and you see that 3.3/5V come from this... IC
          • shuc
            • Jun 2012
            • 30
            I'm afraid what you said is real. I think real powerIC is PU401, page 39, RT8205EGQW. Sorry for previous post. It's my mistake.
            • shuc
              • Jun 2012
              • 30
              http://www.richtek.com/assets/produc...8205ABC-06.pdf
              • vickey_vip
                • Mar 2016
                • 136
                • India
                in my motherboard pu401 is 033a 56088 is this same ?
                • shuc
                  • Jun 2012
                  • 30
                  how many pins have this ic ? It must be like in datasheet.
                  • vickey_vip
                    • Mar 2016
                    • 136
                    • India
                    24 pins
                    • vickey_vip
                      • Mar 2016
                      • 136
                      • India
                      if this is replacment of RT8205EGQW then i must got VIN voltage on pin no 16 as per RT8205EGQW DATASHEET if yes then i not getting there any volatage
                      • shuc
                        • Jun 2012
                        • 30
                        So, on pin 16 you haven't 19V ?
                        • shuc
                          • Jun 2012
                          • 30
                          On pin 8 you must have 3V and on pin 17-5V
                          • vickey_vip
                            • Mar 2016
                            • 136
                            • India
                            how much voltage should be present on pin 16 ?
                            • shuc
                              • Jun 2012
                              • 30
                              19V, more or less... (from charger)
                              • shuc
                                • Jun 2012
                                • 30
                                Then, check on pin 17-you must have 5V and on pin 8-3.3V. If yes, check on bios chip. You must have 3.3V. If yes, firs you need to reflash bios. Sorry I have to go for a time...
                                • vickey_vip
                                  • Mar 2016
                                  • 136
                                  • India
                                  thanks you for your time ill check and reply you result
                                  • shuc
                                    • Jun 2012
                                    • 30
                                    so, found the problem ?
                                    • vickey_vip
                                      • Mar 2016
                                      • 136
                                      • India
                                      sorry for late update problem can't resolved. so i leave it
                                      • redappleguru
                                        • Oct 2012
                                        • 27
                                        • india
                                        RT8205EGQW is not equal to TPS51123 , replace main power chip which is generate 3.3v and 5v , pu401 = RT8205EGQW=DT=CA,DT=CB, Etc..
                                        then check 3.3v on bios chip pin number 8
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • claws77
                                          lenovo flex 5 14itl05 power sequence issue
                                          by claws77
                                          hi guys, my motherboard will not start no matter what
                                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                          but rest nothing happens no sign of life.
                                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                          i have no knowledge of motherboards ....
                                          10-20-2024, 02:48 PM
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • justice171
                                          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                          by justice171
                                          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                          1. Verified that all critical voltages are present:
                                            • 3.3V and 5V are always present if DC is plugged.
                                            • 1.8V on the BIOS chip is present.
                                          2. Checked the power button functionality:
                                            • When pressed, the voltage drops to 0V, indicating the button is functional.
                                          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                            • Confirmed connectivity is intact, ruling out issues
                                          11-26-2024, 12:39 AM
                                        • yaya3gmax
                                          Laptop Power Issue – Works on Battery, Fails on Adapter Load
                                          by yaya3gmax
                                          Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                                          Symptoms:
                                          • Laptop works normally on a pre-charged battery.
                                          • Battery does not charge when adapter is connected.
                                          • Without battery:
                                            • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                                            • Speakers “pop” when power cut occurs indicating harsh sutdown.
                                            • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                                          08-21-2025, 07:16 AM
