Samsung cut out after 30mins Always
  • MJ-meo-dmt
    • May 2016
    • 186
    • South Africa
    I have a Samsung here that cuts out everytime at exactly 30mins. Every single time.
    Details:
    Make / Model Series: Samsung NP300E5C
    Model: Scala3-15/17crv
    Rev: 1.2
    BA41-01979A | PTC
    I need some help with things I could check as I'm thinking that something is timing it and then issuing a cmd to kill power.
    Did Bios update/upgrade
    Checked Cmos batt and circuit
    Tried Other ram / Cpu even tried higher and lower spec cpu. Celeron(intel) & i3/i5
    Reflowed PCH as it got hot.
    Checked for Nec/tokin doesn't have that shit.
    Checked dim Switch. Because if its on and running and you close the lid and reopen the time gets extended but it resets. Example
    Startup 0mins ----running--- 25mins | close lit , awake | time resets and gives exactly another 30mins.
    Its not heat, checked temps checked fan checked pipes.
    Its not windows ran in linux did the same, infact even just having the bios setup screen open it cuts out. No restart just dead / cutout. Starts up fine afterwards.
    3.3 Ok , 5v OK 19v fine, 1.5v fine 1.1v fine Everything power related in the sense of ICs / Mosfets circuit is okay.
    I have an extra BIOS chip in case the actual chip is faulty but thats my last resort as I only have the 1 extact same chip.
    Any ideas would be very helpful.
    Thanks.
    MJ
    while alive { live(toFullest=true) }
  • mielta
    • Apr 2015
    • 368
    Re: Samsung cut out after 30mins Always
    Hi
    Than you have any defect in Bios ME Region
    you can fix it with UEFI Tool
    • Djosla
      • Dec 2012
      • 246
      • Montenegro
      What is the chipset on that motherboard and what is the original cpu...post your old bios dump to fix your me region...
      • MJ-meo-dmt
        • May 2016
        • 186
        • South Africa
        Originally posted by mielta
        Hi
        Hi Mielta, can you elaborate on the "fix it with UEFI tool"
        I would like to learn about this ME Region stuff.
        @Djosla
        SR0T4 (Intel Core i3-3110M)
        SLJ8F chipset
        • MJ-meo-dmt
          • May 2016
          • 186
          • South Africa
          Which tool can I use to make a bios dump?
          • rioreno
            • Feb 2009
            • 540
            • Indonesia
            check your intel chipset, is hm70??
            is your processor i3??
            • MJ-meo-dmt
              • May 2016
              • 186
              • South Africa
              Hi guys thanks for the interest
              Here is some more details as per cpu-z
              Processor:
              Intel Core i3 3110M
              Codename: Ivy Bridge
              Specification: Intel(R) Core(TM) i3-3110M CPU @ 2.40GHz
              Socket 988B rPGA (0x4)
              Chipset:
              Northbridge Intel Ivy Bridge rev. 09
              Southbridge Intel HM75 rev. 04
              Mainboard Model NP300E5C-A09ZA
              • Djosla
                • Dec 2012
                • 246
                • Montenegro
                you have to use eeprom programmer...that is the best way...
                • rioreno
                  • Feb 2009
                  • 540
                  • Indonesia
                  agree with djosla, if you have spi programmer you can try to backup existing bios, and post here maybe someone can help to analyze and fix for you..
                  from your chipset hm75 so clear there's no related cpu issued... because for hm70 cpu issued 30min will shutdown if use i3cpu or above..
                  • MJ-meo-dmt
                    • May 2016
                    • 186
                    • South Africa
                    Damit... I do have a Raspberry & Arduino... Havent had time to finish the arduino custom eeprom programmer circuit... Guess I should do that then...
                    Also for anyone interested some more info on this so called ME region.
                    Links: me_cleaner to neutralize ME firmware
                    Info On neutralizing
                    And pdf about intel ME secrets.
                    The whole ME microcontroller sounds a bit dodge tbh.
                    Anyway
                    @Djosla
                    Since i dont have a programmer do you think replacing the Physical BIOS chip as is would be fine? (I have the exact same chip (and as far as I know it works Ok.))
                    • Djosla
                      • Dec 2012
                      • 246
                      • Montenegro
                      Yes it would be fine...but you also need bios with clear me region preprogramed...you can`t just transfer the chip from different unit...you could have problems...to ensure compatibility with your motherboard,it would be nice to clean me on your dump...
                      • MJ-meo-dmt
                        • May 2016
                        • 186
                        • South Africa
                        Okay yeah that makes sense. Just wanted to find out getting a backup of the .rom would that work? or do I have to get a .bin Dump?? because I have a .rom backup of the bios (the samsung with the issue)
                        *busy setting up the pi with flashrom and seeing if i could pull something from it.
                        • MJ-meo-dmt
                          • May 2016
                          • 186
                          • South Africa
                          Sorry forgot to add ^ that I have this software that enables a person to "backup" a bios to .rom (Software is Bios Backup Toolkit) is that the same as a dumb? or not.
                          • Djosla
                            • Dec 2012
                            • 246
                            • Montenegro
                            It is , but it just does not work properly on many platforms...It does not read properly...Nevertheless you need programmer for writing bios...updating from os just updates the bios region and not menagement partition...
                            • MJ-meo-dmt
                              • May 2016
                              • 186
                              • South Africa
                              Ah okay thanks for clearing that up @Djosla.
                              Well I'll post back here when I have something worth anything.
                              • BenCesur
                                • Jun 2011
                                • 35
                                SLJ8F = Celeron and maximum i3 running.
                                For i5 and upper SLJ8E pch.
                                  09-07-2024, 05:50 AM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
                                  Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                  This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 06:20 PM
