system power ıntegral Supply voltage does not come on 19 V
la-9101p motherboard startup problem
by iT0mT0mHi,
I have problem with detection RAM on this motherboard. When I install CPU(Ryzen 5 2600, 5 4500 or 5 5600G) DRAM Led is lighting all the time. I tried reflash various verion of bios using Q-Flash method and that not resolve my problem. I tried reflash bios by SVOD 4 but that not resolve problem too. All voltages is correct and I don't see any low resistance on coils and other elements on motherboard. I tried replace memory to other and nothing. I don't know where is a problem(maybe connections between cpu and rams socket?). Actually I have boardview for this motherboard and I have... -
by Xristakis795hi to all
I have the above motherboard on which I had windows xp I upgraded it to windows 10 everything went well just when it rebooted and got updates i saw a message for a very short time that windows is trying to fix a problem they found and then the problem was overcome and all is well
the computer works normally without any problems on the internet and in everything
but I found out unfortunately when I had completely cut off the power supply from the network and I went the next morning and plugged it in to turn it on when it went to boot a black screen and the cpu was working...12-28-2021, 06:24 AM -
by hopkokHi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
I checked for low resistance on coils, no low resistance.
Anyone with same issue like me?
Thanks for any help. -
A very old client brought me a recently purchased notebook that suffered a lightning strike and stopped working, as in my region no one does plate repairs, he asked me to help him despite my little experience.
Acer Aspire Vero notebook (n20c5)
motherboard FH5AT LA k092p
The notebook turns on the motherboard LED but does not turn on the fans or even the video or any sign of life beyond that, I tested the power input, the power reaches the battery, I tested some components around the processor, some give 5.7v others give nothing and others are 19v, I haven't found... -
by cihanpcOEM h55 i7 620lm motherboard does not display image. I don't know if it is a bios problem. Is the bios normal?...
- Loading...
